View Full Version : 1970 Chevelle Hydratech system
JuStBlAzIN
01-13-2025, 11:53 AM
Hi All- Looking to upgrade my brakes and saw the lead time is nearly 3 months from hydratech. Figure it was worth asking here.
Does anyone have a complete Hydratech hydroboost system for a 1970 chevelle they want to part ways with?
dhutton
01-15-2025, 03:28 AM
Have you considered using the Bosch iBooster? Much cleaner and no waiting. Andrew has some info in his 70 GTO build thread.
Don
JuStBlAzIN
01-15-2025, 08:50 AM
I started to look at the ibooster, not many cars using them, and the cost is still the same. My cam has 2hg of vacuum, so i need to look at an alternative. If not i will get a LEEDS vacuum pump to hold me over.
dontlifttoshift
01-15-2025, 10:31 AM
Add up _all_ of the costs and I think you will find the iBooster more attractive.
dhutton
01-15-2025, 01:03 PM
I hate Hydraboost systems. They can be so temperamental in my experience. All those damn hoses. Support is almost nonexistent. The iBooster is plug and play.
JuStBlAzIN
01-15-2025, 09:04 PM
have you done the ibooster? How do you like the pedal feel?
dhutton
01-16-2025, 05:21 AM
I have one in process. Andrew is likely your best recommendation unless Donny has done some.
Post 602:
https://www.pro-touring.com/threads/135704-1970-GTO-Version-3-0/page31?p=1386395&highlight=IBooster#post1386395
dontlifttoshift
01-16-2025, 06:13 AM
I have two done but no road miles on them yet. Snow and salt have us on a test drive hold at the moment.
Here is the deal with hydroboost. It got to the point where I wouldn't do them without redoing the entire power steering system. New pump, new hoses, new reservoir to get everything perfect and still end up with a compromise somewhere. Either running more power steering assist than I really wanted or ending up with minor pump noise no matter how much money I spent on a pump or reservoirs. I have never liked they way they felt either......even in my duramax at the OE level the pedal feel is just meh. I swore them off a few years back.
With the availability of the iBooster there really isn't any reason to run a hydroboost at all. From an installation point of view, it is much simpler than a hydroboost and should be maintenance free for the life of the car. The cost is actually less than a Hydratech unit when you add the MC and a prop valve and bunch less when you add hoses. This is comparing to CPPs website for a turnkey solution. If you are handy everything can be sourced for a swap with a used unit as well.
JuStBlAzIN
01-16-2025, 09:07 AM
Going to look into CPP. I was pricing the ibooster with a wilwood master and prop valve and ordering the parts from https://www.retrofitinnovations.com/category/booster-kits
I am leaning on the ibooster, only because it just looks cleaner. I too am not a fan of my tahoe that has hydraboost.
dhutton
01-16-2025, 09:24 AM
Buy a takeoff on eBay. Add an adapter from BBT fab and harness from CPP for a lot less money…
JuStBlAzIN
01-16-2025, 09:32 AM
What is BBT? post a link?
dhutton
01-16-2025, 09:37 AM
https://www.intekotto.com/shop-all-parts#!/ALL-Underhood-&-iBooster/c/167746023
https://www.ebay.com/itm/387693048084?_skw=ibooster+tesla&itmmeta=01JHR2Z70E0FQ1EP1PD5XEJT7M&hash=item5a444e7114:g:TG0AAOSwHZ1nUKt9&itmprp=enc%3AAQAJAAAA8HoV3kP08IDx%2BKZ9MfhVJKlVxrb fd5ApkX8swU1Hq0WkHNASA3sk6rlslJovrpCGcgrHLFFeLNRLz dRbJT1eEbk3vOZgmGYDNAPllDQBAaaZ8Cqb2tT2Phg5gpfcIhb pt7A2ax7rFgk39J%2Bi%2BgkBQ6EOQRU2xLyBMfUXsVJ2ocho9 AvkkNjCw%2FmhSAoC51zid4HTD5LLIetQRhVR%2BneuIeDVj8G UiTlLlOQdv5h9%2FtZYMEJsrgZwj5bDxZMLBJO60gkV0R5Wk2q DmBrDK%2FYT5w6nhQhkthxZ04G8bQLtle%2FWZposqIviR%2Fj Sj5EvbvUY4A%3D%3D%7Ctkp%3ABk9SR57x_IKOZQ
https://www.ebay.com/itm/267012364681?_skw=ibooster+tesla&itmmeta=01JHR2Z70E1X9CNCSZ7PPWET0G&hash=item3e2b2d5989:g:pMAAAOSwq2hm~Fth&itmprp=enc%3AAQAJAAAA0HoV3kP08IDx%2BKZ9MfhVJKkMfPY tNwClPnn7OwcdexwP2uwORG5UNlzuRO7n3LSA9IKY21fkyTU4s MlZD23IedwO2W71hrrYZ7YKM1ETd16ecthbExCTSCjs5s1qYs8 gzPqdNZVQvt1%2FMxqma2mZKXe2bxHJhUKZXI2%2BTMV5H%2BD CAnpSRzi02K%2FNygOrF7l9jOo5yi%2B8urPI9OwpW0JGEvK8y WxNEj297aWi0zp76TWrLb5Y3A6UIPSffwvh32Lad6gJ5Zi8KR6 5iS9wi2B8vnI%3D%7Ctkp%3ABk9SR57x_IKOZQ
- - - Updated - - -
I used the Gen 1 Model S iBooster
dontlifttoshift
01-16-2025, 09:41 AM
BBT is the partner company of Intekotto that machines adapters for the iBooster. I see retrofitinnovations is selling some of their parts as well. There are a lot of ways to do it. Tulays is another source for the wiring harness.
Decide how involved you want to be in the conversion and act accordingly.
JuStBlAzIN
01-16-2025, 10:31 AM
Thank you @dhutton and @dontlifttoshift I am going to read a bit more into them. I think i am 99.99% sold.
I still have rear drums, so i will need to run an inline residual pressure valve. As i do not plan on changing the actual brakes anytime soon. This all started because my new engine produces only 2hg of vacuum.
dhutton
01-16-2025, 10:44 AM
Some good reading here:
https://www.evcreate.com/installing-the-ibooster/
JuStBlAzIN
01-16-2025, 12:19 PM
Great write up. I am going to gather the parts and give this a go.
JuStBlAzIN
12-24-2025, 12:00 PM
Did you get around to testing the units on the road?
Hotwire
12-25-2025, 05:59 AM
Not to derail the ibooster talk but you can easily put hydroboost on your car, units are as close as your local pull a part.
I've been running HB off an 05 Yukon in my 64 for over 8 years now. Only problem was a hose started to leak, went to the nearest parts store and grabbed a new one. I do have a set of an fittings and hose to replace the factory lines, just haven't taken my car down to make the change.
219230
dontlifttoshift
12-29-2025, 08:20 AM
Yeah and I am pretty close to using iBoosters exclusively at this point.
I should note that my CPP experience wasn't great but the 16-20 Tesla Model S iBoosters that I have been using have all worked out really well.
JuStBlAzIN
12-29-2025, 09:58 AM
I am close to calling retrofit innovations for a complete setup. $$$ but easier to pay than to try to figure out how to piece it together for my 70 chevelle.
dhutton
12-29-2025, 04:02 PM
Hi Donny. Are you replacing the master cylinder? I had a heck of a time finding 11 mm inverted flare nuts for the stock master. The ones I found came from Australia.
Don
dontlifttoshift
12-30-2025, 05:58 AM
12 mm x 1.00 is what I used on the installs that used the stock Tesla master cylinder. Got them from Napa.
dhutton
12-30-2025, 06:47 AM
Maybe it was 12mm. My ageing memory is failing me. :( But inverted flare for 3/16 tube was tough to find. Bubble flare is common. The master is inverted flare afaik.
dontlifttoshift
12-30-2025, 08:10 AM
Bubble flare in the master. (according to this, I don't remember and I don't have where I wrote it down.) https://www.evcreate.com/shop/brakes-wheels/brake-line-reducer-tesla-master-brake-cylinder/
These nuts work with both. https://www.agscompany.com/products/steel-tube-nut-3-16-m12x1-bubble?variant=42942616797397
dhutton
12-30-2025, 09:51 AM
Thanks Donny.
JuStBlAzIN
12-30-2025, 01:04 PM
Are you guys using the Tesla master?
dontlifttoshift
12-31-2025, 05:47 AM
Yes when the following conditions are met:
a. Packaging works out and I can run the iBooster in an orientation that allows direct bolt on of the OE master cylinder.
b. The math works out and the 1" bore will move adequate volume with the pedal ratio I am able to achieve.
