avijay75
01-03-2025, 10:40 AM
An amazing build meant to be driven.
Purist look elsewhere, this isn't the build for you, if you are looking for a pro touring/restomod setup, then keep reading.
Extensive build that has all the good stuff, see build list:
VIN: 194379S702453
Corvette Admiral Blue Exterior Paint / Code: WA7057/GTR
BluePrint 396 Engine: $7094.97
- BP3961CTF / 396 CID / 485HP Stroker (dyno -> 494HP, 522FtLbs)
- Fully Dressed Fuel Injection Crate Engine
- Camshaft Hydraulic Roller / Lift .544 intake, .555 exhaust
- Compression: 10:4:1 @ .050, 110 degrees separation angle
- 7-2-2015
FAST EZ EFI (43633): $1500
New Chrome plating: $2200 (with labor)
SSBC Brake system: $2000
- Extreme 4 Piston Black Calipers & Big Bite Rotors -> Front (43mm) & Rear (38mm)
RetroSound Audio, Model #: 25-117720
Rear spindles with axle and bearings $250
TKO 600 Street & Strip Trans. (2.87, 1.89, 1.28, 1:1, .64) $4000
Science Friction 1126 Stage 1 Street Slayer Ceramic Clutch kit $350
- 26 Spline Full Circle Ceramic Matrix Rebound Hub Disc / 620 FtLbs rated
American Powertrain Classics T-Handle Shifter / SLGM-1007, OE Replica Shift Lever
Science Friction Billet Steel Flywheel 168T / pressure plate $300
American Powertrain Console Shift Pattern Plate
Vintage Air/Heat $1900 / Comp Kit Gen IV w/Sanden Compressor R134A
L88 hood / Eckler’s - $750
Rear trailing arms - $480
QA Coilovers (front) - $750
QA rear adjustable shocks - $550
Van Steel front brace - $300
Van Steel rear composite leaf - $550
Vision legend wheels - $800
18 x 8.5” / Offset -6, BS = 4.5” / 5x4.75 bolt pattern
Tires: 245/45/18 — 255/45/18
Paint (Admiral Blue) - $12,000
DeWitts radiator - $800
Hooker headers - $600
Flowmaster exhaust - $900
Borgesson steering box - $750
Rear window & frame - $400
New Door Panels - $846
C5 Z06 Seats - $700
C5 Seat Conversion Kit - $250
35% rear glass tint - $100
Corvette Park Brake Console - $62.69
Shifter Console Lower Housing - $279.99
Shifter Console Upper Trim Plate - $320.99
Interior Screw Set - $39.99
Park Brake Handle Slide/Seal - $14.83
69-76 Radio Access Side Panels - $96.99
Clean and clear title in hand, $55,000
VIN: 194379S702453
- 7-2-2015
C5 Z06 Seats - $700
