View Full Version : LS Oil Port Adapters
badazz81z28
12-02-2024, 04:36 PM
I’m looking to move my oil pressure sensor to the front of the block and my oil temp by the cooler adapter.
looking around, I see the M16 to 1/8 NPT adapters from $8 to upwards of $30! Are these all created equal? I really like the motion works “appearance”, but $28 seems like a lot!
https://motionraceworks.com/products/ls-oil-port-adapter-for-aftermarket-1-8-npt-sensor-m16x1-5-to-1-8-npt-34-00037
https://www.amazon.com/RADREPLA-1-5MM-Engine-Supply-Access/dp/B0CPPRDLNT
sccacuda
12-03-2024, 06:25 AM
China vs US made, so no. The Motion is made with quality material, quality machining, quality seals in the USA. If you have an issue, it's a phone call (that will be answered by someone with product knowledge) away. So again, not even remotely close to equal. Why would you consider putting a cheap Chinese part on an expensive engine?
badazz81z28
12-03-2024, 06:44 AM
How do you even know what’s USA made or not these days…honestly it’s an adapter, I don’t think I’ll be needing tech support lol.
Motioworks doesn’t even tell you what type of aluminum it’s made from?
dontlifttoshift
12-03-2024, 10:18 AM
I've had issues with no name adapters that were missing chunks of threads or tapped to deep to get pipe threads to seal.
ryeguy2006a
12-04-2024, 04:52 AM
If you have an old oil pressure sensor you can drill and tap it yourself. I made one for this car and haven't had any issues after 2 years running around.
sjaroslo
12-13-2024, 11:34 AM
The part that you linked to shows as $17? I know that I bought a kit of brass adapters from someone (can't remember who) and as soon as I went to tighten up the sensor in the fitting, the fitting ripped right in two! The Motion Race Works part that was linked to looks pretty beefy to me.
badazz81z28
12-23-2024, 05:34 PM
any pros or cons using aluminum or the brass sold by Autometer?
slazisme
12-26-2024, 09:26 AM
I used this one from Earls, made in USA of 2024-T8 aluminum.
https://www.holley.com/products/plumbing_an_fittings_and_hose/application_specific_parts/ls_plumbing_parts/oil_system/parts/LS0021ERL?srsltid=AfmBOoq394HiJehsoFihcaiIlaZJTG_5 XoaMLP8z2LvKt_5L4x6cY4jE
Used a different crush washer that I could feel compressing once it became snug.
https://www.rallysportdirect.com/products/subaru-oem-oil-drain-plug-crush-gasket-16mm-subaru-models-inc-2015-2021-wrx-2013-2020-brz
