View Full Version : Crazy Idea: Using a Brake Disc a Bolt Pattern Adapter
CTX-SLPR
11-12-2024, 10:31 AM
Howdy,
So I have an Infiniti Q45 IRS sitting around waiting to go into my '64 Riviera. This will require custom fabricated front spindles so the front hub is wide open. I'm torn between using the native 5x4.5in wheels and redrilling the C6/7 front rotors or using C7 hubs in the front and going 5x4.75in in the back. Since the Q45 rear hub is not a full round flange:
215261
To keep from stacking offset, could you use the rotor hat to mount the wheel studs to fit between those arms?
ryeguy2006a
11-13-2024, 04:49 AM
You could contact CPP about buying two of their hubs. They sell a kit for Mustang II front suspensions and C5 brakes with the hubs and rotors being dual bolt pattern.
