View Full Version : Glove box door lock removel
PhillipM
01-15-2006, 02:09 PM
I'm ready to paint my dash but still cant get the lock mechinism out of the golve box door to paint it! Please help.
jamesg602
01-15-2006, 04:45 PM
Did you get it removed? What type of vehicle is it on? :candle:
toxicz28
01-15-2006, 06:12 PM
Two questions:
1. What kind of vehicle?
2. Do you have the key for it?
A 69 Camaro (and I'm sure other GM vehicles) needs the key to remove the glove box lock. I'm not sure of the proceedure. Since I didn't have the key to mine, I put it in a drill press and drilled most of it out. I then used a propane torch to heat the pot metal retaining ring up. I heated it just enough to soften it, and pried it off.
One more thing, there is a plastic washer between the retaining ring and the panel.
PhillipM
01-16-2006, 10:00 AM
I ended up getting it finally. It was a GM lock on a Camaro. I finally found the little tab on the back that I pushed down and the lock tumbler came out. What a PITA!! Thank you for the replies though
jeffandre
10-10-2006, 09:18 PM
I cannot figure it out how to get the lock assembly out of the glove box door on my 71 Camaro. I do not have a key for it, so I am willing to buy a new lock setup anyway. Please help...thanks,
