1badchicken
10-29-2024, 11:11 AM
1969 Chevelle badged as a 307 Malibu.
this car is stunning, completely sorted and a blast to drive.
started out life as a original surviver car. Super solid.
read the complete build list. If you know you know.
Frame off Restoration. Including underside painted body color.
All new exterior trim, bright work moldings.
New seals
All New glass.
Original bumpers Re-chromed bumpers.
All new wiring.
Body mounts bushings.
Billet aluminum hood hinges polished.
New GM create LSX454 with GM controller. Drive by wire throttle. OBD-2 port.
Dynatech 3” stainless exhaust.
Stainless works headers.
Vintage Air front runner accessory drive.
Vintage Air HVAC system.
Proper EFI fuel tank and complete fuel system.
High torque mini starter.
Dekota VHX factory appearing gauges.
Flaming River tilt steering column with billet levers.
New Tremec T56, 6 speed hurst shifter. Hydraulic clutch with bowler performance hydraulic slave. McLeod RXT twin disc clutch.
Big aluminum radiator with twin fans.
HPI frame kit. See photo.
Speed Tech suspension
Upper and lower control arms
1 5/16 sway bar front.
Front and rear Viking warrior double adjustable Coil overs.
Track time rear tubular adjustable sway bar.
AFX spindles A body ADD steering arms.
670 steering box 12.7:1 ratio.
Currie rearend 9’ big ends 33 spline axels. C clip eliminators.
True track posi 3:73 ratio.
1350 yoke.
Factory powder coated.
Strange Engineering Chromoly driveshaft.
Brakes are Wildwood C6 6 piston front W6A, 4 poston rear with 14.4 drilled and slotted rotors. Proper proportioning valve for hydroboost.
Hydroboost with wildwood master cylinder.
Optima battery trunk located.
New Tremec T56, 6 speed Hurst shifter.
All New interior including new seat frames, seat foam. New carpet and headliner.
Retrosound Model 2 head unit.
JL Audio amps.
Sub, Hurtz speakers front and rear.
Sounds fantastic.
Rushforth wheels
Nitto NT555R 305/35/20
Nitto NT555 275/35/19
$85,000 firm
more photos and videos available on request.
New seals
All New glass.
All new wiring.
1350 yoke.
JL Audio amps.
Sounds fantastic.
Rushforth wheels
$85,000 firm
