    Results 1 to 20 of 28
    Thread: Ridler 652
      Ridler 652
      So I really like the look of these Ridler 652 and the US Wheels Bandit, but they are only 9.5" wide and 9" wide respectively. Anyone seen something super similar I could get it a wider size with an 18"? I think they would look great on my 70 Judge. My biggest draw with these is the cost. I think both are less than $300 each. I even thought about having the wheels widened. I think it's around $350 each to have them done. Still be in them for less than $700 each for the back ones. Fronts should be fine. What have you seen like these for the same sort of money?
      https://www.ridlerwheel.com/652-glos...k-diamond-face
      Apr 2016
      What size tire do you plan to run or what actually fits 70 judge.
      That's a good question that I am not 100% certain on. I'm planning to run at least a 295 or maybe a 305, probably in a 40 series. I've heard of people running a 295 on a 9.5" wheel, but it doesn't appear to be recommended. If I can stuff a 305 in there I would like to.
      I really like the look of this, but with that deep dish I'm sure that's a $1200 custom size wheel.
      Edit: my mistake a custom 18x11 is $1528, not $1200.
      May 2013
      At The Lake
      I have 285/40/18s on a 18x9.5 with 5.5" bs the back of my 69 Tempest. I don't think a 305 would fit unless you shorten the axle and went to a custom offset wheel.
      1970 Chevy Kingswood
      1969 Pontiac Custom S
      I am having a custom 9" made for it, which is why I want to pick the wheels first.
      Mountain Springs, Texas
      Will a 305 fit without minitubs? I would have thought that would require minitubs and that usually means narrowing the frame.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      With my rough measurements it looks like it would without mini tubs.
      Dang. Only tire I see in a 305/40r18 is a Nitto 555. That's crazy!
      Apr 2016
      I've seen 305 on 18x10 on the back of a few chevelle's, but those had mini tub and custom rear. I'd buy the Ridlers and have them widen for the price you noted above as I don't think anything similar will be even close to that price.
      Agreed. I guess I need to decide how bad I want 305's. I could probably get away with 295's on a 9.5" wheel.
      That’s a lot of effort for an extra .4” of tire width.
      Then again…
      Yes it is.
      I want to run a 255/40r18 in the front. Would I want an 8" with 4.5" BS or 9.5" with 5.25" BS wheel for that? That's the only 2 options I have in my wheel choice.
      Apr 2016
      Although lots do it 255 on 8" its not ideal why not go with a 245 in the front. Will the 9.5 fit without frame interface
      I have no idea what will fit.
      I know guys run a 9.5 in the front, but they seem to all have more back space than 5.25".
      Post number 7:
      https://www.pro-touring.com/threads/...l-tire-fitment
      Real world experience from Andrew.
      Ok that's awesome! Seems like either might work. If he had 6.5" backspace on a 9.5" wheel with a 1/2" spacer (putting it at an effective 5.5"), these at 5.25" are only 1/4" difference. Although surely he's not running stock type suspension or brakes, so there will be a bit of variance.
      A half inch spacer on 6.5 inch backspacing makes it 6 inch backspacing not 5.5. 5.25 is not going to cut it imo.
