View Full Version : Late model Z28 rearend in my 1971 Nova ???
TRILOGYZ28
09-26-2004, 08:29 PM
ok, got a few questions for ya guys!
i am looking at putting a 98+ Z28 rearend in my 1971 Nova.
here's what i got so far.
stock 1971 Nova rear is 59.5 inches wide (outside lug stud flange to outside lug stud flange)
stock 1998+ Z28 rear is 64.75 inches wide (outside lug stud flange to outside lug stud flange)
for one, i know i'll have to cut all the old mounts off the Z rear and weld the stock mounts from the 71 Nova rear onto it.
thus, this will let me run a more higher positive offset wheel under my nova. (letting me achieve the look of a stock "face" depth wheel from a side and 3/4 view, but when you would look from directly behind the nova you will see alot of width stuffed under the car) kind of a "sleeper" look.
my main question is.
would this in any way adversely affect any handling of the nova??
(btw, i'll be running DSE deeptubs with the offset hangers)
zbugger
09-26-2004, 08:51 PM
I don't really see how it would. What's the front track width gonna be in comparison?
TRILOGYZ28
09-26-2004, 09:04 PM
the front suspension setup will be a Wayne Due clip, i can have wayne make the track width very close to the rear track width. (maybe... :dunno: )
i do recall that the "mule" was running a Wayne Due front clip also, and had high positive offset wheels on the front.
zbugger
09-26-2004, 09:11 PM
Remember that your 4th gen has a similar setup. Find out the track on that and maybe you can have Wayne set up your Nova subframe pretty close to that.
09-26-2004, 09:13 PM
why not leave the 4th gen mounts on the rear and fab up a link suspension for it? That will give you alot of tuning oppertunity...sorry had to plant the seed...its a sickness I swear :dunno:
TRILOGYZ28
09-26-2004, 09:24 PM
gee, thanks vince ! :slap: :wedgie:
LOL !
TRILOGYZ28
09-26-2004, 09:28 PM
Thanks allen......i have had the gears turning in my head today thinking and measuring these, just been needin a lil input. :cheers:
now (thanks to vince :slap: ) they are turning in Overdrive.
09-26-2004, 09:51 PM
ha ha wise guy, nuck nuck i knew I smelled burning bacon?!?! oil dem bearings! he he :seizure: <----chuck
Q ship
09-27-2004, 09:55 AM
Just my opinion, but if you are planning on building decent power/traction a late model 7 5/8" rearend is not what I would want. It's a great idea in concept, but it would suck to pop the rearend after doing all that work.
TRILOGYZ28
09-27-2004, 10:20 AM
i am just installing a stock 98+ ls1 drivetrain for now, so the stock ls1 rearend should be ok.
if i plan in the future to turbo or supercharge the ls1, definetly a 9 inch or 12 bolt would be in order.
LS1NOVA
09-27-2004, 12:24 PM
Personally, I Would Just Spend The 2,000 Now And Get A 12 Bolt Or 9 Inch That Wide To Start. Those 7 5/8 Rears Arent Even Good Enough For A Stock Lsx Combo Even In Stock Form. Nothing Like A Rearend Failure To Wreck A Nice Weekend Outing.
RSSSLS1
10-05-2004, 12:51 PM
I agree with LS1NOVA, the factory rearends in the 4th gen's are very weak. Go to www.ls1tech.com, under the rearend section, everyone is switching to a 12 bolt or 9 inch. The 7 5/8" ring gear is the same they use in s10's & astrovan (not big horse power viechels)
I have had problems twice on my 99 ss.
Just my opinion, but if you are going to do the fab work, make it worth it.
Later, Jeromie
