badmonza
08-13-2024, 04:00 AM
Completed in 2023 built by Octane & Iron (magnolia,Tx.)
Camaro was featured in Chevrolet Performance Magazine
Engine:
Gen.4 aluminum 376 ci
Rotating assembly-cast iron crankshaft, Hypereutetic aluminum pistons, 6.098 inch ibeam powder coated metal rods
Compression-10.1:1
Bore-4.000 inches
Stroke-3.622 inches
Texas speed magic stick 3 (0.600/0.0600 lift 238/248 deg. duration at 0.050, 112 lsa.
Cylinder heads-cathedral port
Induction:
Holler Sniper intake manifold w K&N airfilter.
Power adder:
Procharger D-1SC
Accessory drive kit: Procharger
Exhaust:
Headman headers 1-7/8” w 3” custom exhaust with Borla pro xs mufflers. Custom EVOD exhaust tips
Ancillaries:
Ring brothers hood hinges/door handles, Detroit speed electric windshield wiper motor, Spal duel electric fans, Afco aluminum radiator, 140 amp power master alternator, Motion race works valve covers, MSD wires, Fragola fittings and hoses, custom intercooler piping, Ricks fuel tank w ZL1 fuel pump Vaporworx fuel system, Anvil auto carbon fiber inner fenders and header panel.
Engine Output: 605 RWHP
Drivetrain:
Tremec T-56 magnum 6spd. by American powertrain,
12 bolt Eaton trutrac posi track w 3.73 gears 33 spline w Moser axels.
American power train twin disc clutch
PST 3.5 inch aluminum driveshaft
Chassis:
stock w Hotchkiss subframe connectors
Steering: Borgeson
Front Suspension:
Ridetech spindles w Ridetech coilovers double adjustable shocks. Ridetech tubular control arms, Ridetech muscle bar.
Rear suspension:
Ridetech triangulated 4 link, double adjustable shocks, Ridetech muscle bar. Wheel tubs- Detroit speed mini tubs
Brakes:
Wilwood 14” rotors, 6 piston drilled/slotted calipers front, Wilwood 13” rotors, 4 piston drilled/slotted calipers rear. Wilwood manual master cylinder, brakes are setup perfectly
Wheels & Tires:
Forgline GA3C transparent gold inners/flat powder coat outers (18x8 front 19x12 rear) Michelin pilot sport 4S (225 40 18 front 325 30 19)
Interior:
Tight red loop carpet and red ultra leather.
Door panels, Center console, Headliner, dash, seats, custom by Sublime Heights (Magnolia Tx.)
Rockford Fosgate stereo with bluetooth
Ididit steering column w Billet Specialties steering wheel.
American Powertrain shifter
Stock dash with Detroit speed insert, Racepac cluster with push button start.
Optima yellow top battery in trunk
Vintage air and heat
American Auto Wire entire car
Insulation-Lizard skin
Exterior:
Body work and paint by RF customs (magnolia, Tx.)
Paint: PPG Magnetic Grey Metallic
Hood-GM factory
Front/Rear bumpers- tucked
Headlights: H4
Taillights: Fesler
Fesler Front/Rear flush mounted glass
Stock bullet side mirrors
Approximately 1200 miles on build
Asking $159,000 OBO Call or text 3376606186
21439521440221440421440021439321439821439621439921 4403214405
Engine:
Compression-10.1:1
Bore-4.000 inches
Stroke-3.622 inches
Induction:
Power adder:
Procharger D-1SC
Exhaust:
Ancillaries:
Drivetrain:
Chassis:
Steering: Borgeson
Front Suspension:
Rear suspension:
Brakes:
Wheels & Tires:
Interior:
Exterior:
Hood-GM factory
Headlights: H4
Taillights: Fesler
