View Full Version : 1972 C15 GMC I call Warhawk
zbadone79
08-04-2024, 03:19 PM
This is my 1972 GMC C15 that was originally purchased by my Dad new, in 1973. Still on the dealer lot. He said everyone else want the new body style coming out. I'm pretty happy with this one. It was a long bed Sierra Grande. Two tone white with yellow. It had a 402 BBC TH400. The lovey wood grain interior, with no Tach. I have been through a few different setups with this truck, Starting with just a fresh rebuild/cam/intake/headers of the 402. Drove it around then let it sit. Pulled that motor out and put a 383 SBC out of my 79 Camaro Z28. Used a Sniper EFI on it. I also redid alot of work on the truck at that time. Cab corner and lower rocker panels. Shortened the bed and frame with the Brothers kit. Used CPP front control arms, and converted the rear suspension from leaf spring to CPP trailing arms. Relocated the cab fuel tank to the rear, using a Boyds welding fuel tank.
The last conversion was to a 5.3 LM7 with a 4l60e using a FITEch setup. I also installed a frame stiffener at the time the engine was out. Very happy I did that. Running QA1 single adjustable shocks in the front and QA1 double adjustable shocks in the rear.
Brakes are Lil Shop MFG 14" Wilwoods in the front, with 12 CPP rear disc conversion in the rear. Running Wilwood master cylinder on a hydroboost with an adjustable proportioning valve
zbadone79
08-04-2024, 03:26 PM
214225214226214227214228
- - - Updated - - -
214229214230214231214232
- - - Updated - - -
214233214234214235214236
- - - Updated - - -
zbadone79
08-04-2024, 03:37 PM
214246214247214248
zbadone79
08-04-2024, 03:41 PM
214249214250214251214252214253
zbadone79
08-04-2024, 03:54 PM
214254214255214256214257214258214259214260
- - - Updated - - -
214261214262214263214264214265214266214267
- - - Updated - - -
214268214269214270214271214272214273214274
zbadone79
08-04-2024, 04:16 PM
214290214291214292214293214294
- - - Updated - - -
214295214296214297214298214299
zbadone79
08-04-2024, 04:19 PM
214300214301214302214303214304214305
zbadone79
08-04-2024, 04:21 PM
214306214307214308214309214310
zbadone79
08-05-2024, 03:50 PM
214319214320214321
zbadone79
08-05-2024, 03:52 PM
Frame stiffener from Summit Racing. I don't believe they carry it anymore. I really like the way it installed and the way the truck feels with it. It did make a big difference in rigidity
214322214323214324214325214326214327
mikewoods
08-06-2024, 05:50 AM
Awsome truck! Thanks for sharing
zbadone79
03-03-2025, 11:11 AM
Went to a photo shoot with Sand Photography this weekend. Excited to see some of the rolling vid and pics he took. Here's a couple
216424216423
Brentm
03-03-2025, 01:24 PM
Cool truck! I like how you used the small details together inside and out.
kawasakii
03-03-2025, 10:36 PM
Cool truck and nice to see the detailing.. Look forward to seeing more projects and pictures.
zbadone79
03-04-2025, 12:48 PM
Thanks for checking it out
- - - Updated - - -
Thanks. It's a work in progress. Fun to do some details, but trying not to be to tacky.
zbadone79
03-25-2025, 07:53 AM
21663821663921664021664121664221664321664421664521 6646
Some Pics from my recent photo shoot
zbadone79
06-30-2025, 12:38 PM
I took some more time to work in my engine bay. I never really liked the mounting brackets for the hydroboost, so removed those and got a flush mount bracket. It did work, but I had to do a little firewall massaging to make the rear of the hydroboost fit in the brake booster hole. I also had to shorten the rod connected to the brake pedal. I am still using the original hole and the brake pedal. It seems fine.
After relocation of the master cylinder unit to the firewall, I decided to change my boost lines to stainless. I had seen these lines on Big 10 Garage trucks and really liked the way they looked. I took a bit a learning what I had to use to deal with stainless lines. I invested in a Ridgid 37 degree flaring tool, tubing straightener, several different AN connections, and a good tubing bender for 3/8.
68Formula
06-30-2025, 04:25 PM
Badass
Josh@Ridetech
07-03-2025, 05:27 AM
Very cool. I love the look of it! Good work man :cheers:
zbadone79
07-06-2025, 12:20 PM
Thanks for the compliment
zbadone79
07-28-2025, 08:13 AM
Some pics of the stainless lines I did for the Hydroboost, plush flush mount on the firewall 217825217824217823
ztk123
07-28-2025, 05:27 PM
Looks great! Carbon fiber intake tube looks great too!
Raszaron
07-29-2025, 08:26 AM
Fantastic job on Warhawk! I love working on these old Chevy trucks as each can have a really cool story or theme, and I really like how you had a theme and you stayed true to it.
zbadone79
07-29-2025, 09:10 AM
Thanks, I pieced it out with 4" carbon fiber tubing/elbow off of Amazon. Cut it down to length
