View Full Version : CCW crankshafts - Are they worth having?
Zachalanche
06-24-2024, 08:12 PM
Curious if anyone here has ran a crankshaft with center counterweights (CCW)?
Calles and Dart are the 2 manufacturers that I am aware of that make these. Allegedly the crank has better stiffness which reduces bearing wear under high loads and rpm. Is it worth a few hundred bucks in additional cost for a 600 hp stroker running up to 7000 RPM? is there any performance benefit?
slazisme
06-28-2024, 04:42 PM
Personally don't have experience with CCW cranks but this article sheds some light on using it.
https://www.enginebuildermag.com/2023/11/crankshaft-counterweights/
With the power you're running are you using a GM LS3 block for your stroker foundation? I would think a aftermarket block though expensive might be a option to consider if the funds allow. Any damage to the thrust bearing main cap? How about for a balancer you're using....... ATI, Fluiddampr?
Maybe check with these guys they would probably be best to advise you since they build a lot of their engine with CCW crankshafts.
https://borowskirace.com/products/callies-center-counterweight-magnum-crank-for-ls-engines?variant=5992687403035
