View Full Version : 68 Camaro BS with stock width 9 inch
brickyard69
06-09-2024, 09:45 PM
I purchased a 68 Camaro with Ridetech 4 link BUT it has the stock 60 inch width Currie 9 inch vs the preferred shorter one.
Can someone tell me what backspace I would need with a 12 inch wheel? Everything I see is with the 54 inch Currie.
I Dont have the car available to measure myself.
I am guessing somewhere around 8.75.
Thank you in advance.
btmatt
06-10-2024, 05:37 AM
we have 19x12 using 8" BS on our Camaro (60") width
all cars are different tho and I would confirm
dhutton
06-10-2024, 12:39 PM
A ten inch wheel with stock tubs would have 5.75” backspacing. So assuming 2” wider tubs, a 12 inch wheel would be at 7.75” backspacing. Would I order based on that, no I would not. I would measure it to confirm.
The above assumes no brake offset due to aftermarket brakes.
Don
brickyard69
06-10-2024, 02:02 PM
How much offset do aftermarket brakes require? I have Wilwoods.
dhutton
06-10-2024, 04:52 PM
How much offset do aftermarket brakes require? I have Wilwoods..
It varies you will need to find out for your specific brakes.
