View Full Version : 69 camaro 22inch or 24inch rear rim
Steven69
05-12-2024, 04:26 PM
Hey guys I am trying to figure out how to fit 22inch or 24inch rim in the rear do I have I to use mini tubed or full tub and whay else I need to do to make this happen any help thanks
dhutton
05-13-2024, 09:07 AM
Minitubs are to accommodate wider, not taller, tires and wheels.
Vimes
05-13-2024, 04:13 PM
This the look you're going for? Gonna take a lot of metalwork to stuff those in, plus a narrowed axle. You're also going to need a one-off suspension as none of the factory stuff is going to work. A Camaro factory wheel track is about 59 inches, so removing 30 inches from that leaves you 29 inches to stuff the rear suspension in. The front suspension will also need a lot of work, and you may wind up needing a full frame to do this. Handling will also be a real challenge with the suspension mostly inboard on the car. Suspension works best at the corners, not from the middle. It would be better suited as a drag racer, but I'd not want to hit a hard corner in it. I doubt there would be a back seat either, as those wheels dig deep into the seating area.
Here's a pic on a 69 Camaro on 24x15 wheels.
https://static1.pt-content.com/images/pt/2024/05/maxresdefault-1.jpg
This youtube link shows who built it, might get advice on what it takes there.
https://www.youtube.com/watch?v=MMfp0OK8D_g
19/20s would be a lot easier to fit in, and would look pretty good.
https://static1.pt-content.com/images/pt/2024/05/69CamaroS7polishside12x6-1.jpg
Steven69
05-13-2024, 05:02 PM
I wouldn't do 24x15 maybe 24x12 or 22x12 the car look great some people said full tubes some say mini tube if I wanna fit the 24in and they have back seat with mini tubes
Hotwire
05-15-2024, 11:35 AM
Looking good and still being a functional car are 2 very different subjects, and one of those subjects is very opinionated..
Steven69
05-16-2024, 04:08 AM
I have seen the camaro first gen with 22inch now what he did to make them fit I have no idea would any know or point me out on the right Direction thanks
