View Full Version : my current tube project
Travis Rankin
01-13-2006, 03:33 PM
Its going on a '62 Nova
Travis
F70t/a
01-13-2006, 03:43 PM
What kind of suspension is that? the fab work looks sweet :worship:
Travis Rankin
01-13-2006, 03:48 PM
Thanks!, Mustang II basically
TUBED
01-13-2006, 10:23 PM
Travis,
Is this mild steel or 4130 and what size? What type of bender are you using? It's certainly a different approach.
Gerald
Travis Rankin
01-14-2006, 12:24 AM
Mild steel, 1.75" and a little 2" I'm using a JD2 bender with hydro
PT Dave
01-14-2006, 07:40 AM
Travis,
how much effort does it take to bend the tubing that you are using (with the JD2) ? Also, does it "kink" the tubing ?
Dave
killer69
01-14-2006, 10:29 AM
WE also have a JD2 bender with the Enerpac hydro on it and it works really well i can bend a .120 wall 1.5 tube in a 180 and there is virtually no distorsion. the thinner stuff might deform a bit but it works well
Travis Rankin
01-14-2006, 12:24 PM
Yup, a full 180 with virtually no distortion. and almost no effort pulling the hydro lever :D
I ran it without hydro for awhile, and damn that was alot of work.
Travis Rankin
01-17-2006, 03:14 PM
F70t/a
01-17-2006, 03:37 PM
What are you doing with the rear? hopefully something trick like the front :firefire:
Travis Rankin
01-17-2006, 03:40 PM
The owner has allready installed a truck arm setup
Travis Rankin
01-17-2006, 07:25 PM
whoops! I had some clearnce issues
take two:
