View Full Version : Kong LSA / LS9 Low Vacuum Bypass Valve
Hopperj7
03-03-2024, 01:58 PM
New, never been used or installed Kong LSA / LS9 Low Vacuum Bypass Valve. Necessary if you are running a larger cam.
I sold the motor I was going to put this on, so I never used it.
$150. Located in Monterey, CA. Can ship at buyer's expense.
212519212520212518
"This low vacuum bypass is a direct replacement for the LSA / LS9 OEM bypass. It is designed to open and function properly on low vacuum engines. Stage 3/4 camshafts in LSA/LS9 engines do not pull enough vacuum to open the OEM bypass valve all the way. This results in poor gas mileage, poor drivability, and decreased supercharger life. The Kong low vacuum bypass valve is the first and only direct replacement option specifically designed for these engines." Kong LSA / LS9 Low Vacuum Bypass Valve – Kong Performance (https://kongperformance.com/collections/2009-2013-zr1-modifications/products/kong-lsa-ls9-low-vacuum-bypass-valve)
Hopperj7
03-12-2024, 10:08 PM
Sold
