View Full Version : FS: Comp Cams Beehive Valve Spring Set 26120-16
67L88Vette
01-26-2024, 06:41 PM
SOLD!! Up for sale is a nice set of 16 seasoned Comp Cams 26120 round wire beehive valve springs (p/n 26120-16 for a set of 16). This spring set is used, but not used up! I ran them on my hydraulic roller BBC motor in my tow vehicle. These are great springs for a street driven motor that uses mild to moderate rate roller cams. The specs on the springs are:
Max Lift: 0.600
Installed Height: 1.880
Coil Bind Height: 1.230
O.D. of Outer: 1.059/1.444
I.D. of Outer: .650/1.000
Spring Style: Beehive
Spring Rate: 370 lb/in
Seat Pressure: 155lbs @ 1.880
Damper: No
I cleaned the spring set, and measured the load at both installed height and open height with my benchtop valve spring checking tool, and all springs were in spec. Installed height loads ranged from ~172lbs to just under 180 lbs, and the load at 1.28" spring height ranged from 372 lbs to 380 lbs. Don't miss a chance on these lightweight valve springs for your street build, or to have as spares for you racers. Asking $125 shipped in the lower 48 United States. Thanks for looking! SOLD!!
211854
67L88Vette
02-17-2024, 10:21 AM
To the top ... Still have these springs and happy to take offers ...
John A, 67L88Vette
