View Full Version : HELP! Wiring 2017? Mustang seats
chpr1972
01-23-2024, 09:03 PM
Where can I get a wiring diagram for 2017/newer Mustang seats. I was told power and a ground. Anyone know what wire to disconnect the airbag. I do not need anything other than back and forth and sear back angle moved.
Hotwire
01-24-2024, 10:33 AM
there should be a bundle of wires with a bright yellow sheathing, those would be the airbag wires, just connect them together or run them to a ground and you'll never have to worry about them again.
If you google "2017 mustang seat wiring diagram" you'll find all the info you need.
chpr1972
01-24-2024, 03:35 PM
i GOOG;ED 2017 mustang seat . wiring harness first
TitanFox
01-25-2024, 05:39 AM
If your friends with a mechanic you ask them to print off the wiring schematic for the seats.
joeko23
01-26-2024, 02:35 PM
Take a look at this post. I think that’s what you are looking for.
https://www.mustang6g.com/forums/threads/how-to-enable-heated-cooled-after-swapping-from-base-to-premium-seats.129230/
chpr1972
01-31-2024, 06:25 PM
Lost cause. They are controlled through the cars computer So far as I can find out, no one has made a mini computer to make them work
joeko23
02-01-2024, 08:11 AM
Don’t think it’s a lost cause. I got my BMW seats to work and they also work on a canbus system. As long as you have controls on the actual seat and the seat has a computer you can power them up. First find the thick Violet/Red (pin 9) wire that’s your 12v+ wire. Then find the thick Black/Blue wire (pin 7) that’s your Negative/Ground. See if the seat does anything even if it’s for a few seconds.
Canbus system is fairly simple it just sends a signal to the seat to keep it “awake” or functioning. Report back if you can get the seat to power up with just the 2 wires I mentioned.
