View Full Version : 3 point harnesses in a vert?
Johnny Blaze
01-13-2006, 10:08 AM
I thought I saw a tread, but was unable to find it.
I would like to add shoulder belt to my 67 vert but am unsure how this could be done.
I would prefer not using seats like billygoat.
If anyone has pics, links of info, please share
Damn True
01-13-2006, 10:25 AM
There was a 3-point belt system for the 1st Gen verts, but IMO it dosen't look like it would do that great a job.
A seat with an integrated belt (Sebring seats in Billygoat) may be your only option. The Bimmer 3-series verts have an integrated belt in the seat as well http://www.bmwusa.com/NR/rdonlyres/CFC68B70-EA0E-49B2-B449-62A67A60493B/0/0441_08.jpg http://www.bmwusa.com/NR/rdonlyres/81C4C19C-107C-40C1-8FD6-72D32DB72453/0/0441_03.jpg .
BonzoHansen
01-13-2006, 11:04 AM
I think some late model Caddy seats do to.
protour_chevelle
01-13-2006, 11:24 AM
99+ Chevy pickups have them built in. 03's+ are by far the nicest ones.
-Matt
Johnny Blaze
01-13-2006, 11:28 AM
WEll, the problem I see with most of the seats with the built in belts, is they just look to big, too wide.
Billygoat is an awsome car, and looks amazing, but those seats just look out of place to me. They look like somethingout of a 77 cadillac.
Thanks for the help though!
CAMAROBOY69
01-13-2006, 11:55 AM
What if you had a roll bar? Im sure there would be an easy way to attach to that.
Johnny Blaze
01-13-2006, 12:19 PM
Yeah, a roll bar would make things easy.
This car will be a street driven car, will not see the track.
I think rol bars look funny in a vert, unless done right. I am trying to come up with a clean roll bar that doesn't make the rear seat useless though.
Damn True
01-13-2006, 01:03 PM
You can't have a cage/bar that will function appropriately as rollover protection and harness mount AND still use the rear seat. Dig the "Breaks my Heart" thread for reasons supporting this statement.
Johnny Blaze
01-13-2006, 01:12 PM
Well, again, I am not building a race car. I have read though that thread and understand.
I know a full cage and 5 point harnesses will provide the ultimete protection, but I am just not willing to go that extreme.
I have a race car with a full cage for that.
But I figured 3 point harnesses would be a fairly easy addition and would help greatly.
After all, the factories are still spitting out verts with out roll over protection.
Damn True
01-13-2006, 01:24 PM
Well, like I said there is/was an OE system that was an option in the 1st Gen vert. If you look behind the side panel in the back seat you will see the mount hole for it.
IMO it isn't that great of an option because of the angle the belt comes over the seat.
Here is a link to a couple aftermarket versions of the OE system.
http://www.wescoperformance.com/i-3207-retractable-install.htm
http://www.the-direct-source.com/product_info.php?cPath=105&products_id=486
Like I said, from a safety standpoint you are better off going with something that integrates the belt into the seat backrest. It places the belt at a more appropriate angle. No way the old OE system would get past DOT tests these days, those seats in the Bimmer do.
Run down to your local Bimmer dealer and take a look at the vert. The seat is much leaner than the Sebring seat.
Johnny Blaze
01-13-2006, 05:01 PM
That bimmer seat is sweet, but what would they run?
Damn True
01-13-2006, 05:19 PM
From a dealer probably a ton. From a wrecking yard and then recovered in the fabric of your choice....a lot less.
Bill Howell
01-13-2006, 05:24 PM
The only issue I have with my seats are that they sit high. Almost too high for me to sit in the car with top up. In a first gen, they would be even worse, so be careful when choosing a replacement. It would be best if you could actually test fit before you buy.
BonzoHansen
01-14-2006, 06:29 AM
Found this.
ebay item 8027659195
04 Deville Black Leather Front w/Belts
http://images.mainstreetcommerce.com/3.9/media/get_image.aspx?domain=lkqcorp.com&image_guid=2a4d530f-ad7d-45cb-98ef-c037a027b388&size=2
Johnny Blaze
01-14-2006, 07:14 AM
Those aren't bad.
Kenova
01-14-2006, 07:23 AM
I have an '04 Silverado with the integrated seat belts. They are, without a doubt, the most comfortable seat belts I have ever used. This type of seatbelt system will deffinetly wind up in my Nova, and if I can find a seat small enough, my Vega too.
Do a search on E-bay for "front seats" to get an idea of what is out there. More and more cars and trucks are using these belts.
Ken
69muscle
02-09-2006, 05:09 PM
check out wise guys seats. they have a 3 point system attached to the seat frame
ProTouring442
02-10-2006, 03:03 AM
I have been working on this same problem in my head now for a year or so. My idea, though untried, is to attatch the upper mount to the rear inner 1/4 but with a twist. I want to mount it more towards the inside of the car to reduce the silly angle of the belt. This means making a custom inner panel that is "thicker" to hide it and make it look more "factory." This will be complimented by a "thicker" door panel, making it easier to hide speakers. I hope this makes sense, I haven't finished my coffee yet!:sleeping:
Damn True
02-10-2006, 10:55 AM
There was a thread that floated around for a bit with a black '67 vert with a black & brown interior. It had a rather clever harness bar behind the seat. Made the back seat totally useless though.
PTAddict
02-10-2006, 12:12 PM
I'm installing Wise Guys three point seats in my wife's '55 Belair hardtop. They have a much more traditional look than the late model seats.
http://www.wiseguys-seats.com/
FScope
02-11-2006, 02:59 PM
I have modified the rear panels in my 68 conv to enclose 3 point seat belts from a LS1 camaro conv. I am using the seats from that car also which makes it easier because the rear seat is narrower than the original. here is a link to a picture in vbgarage- https://www.pro-touring.com/forum/vbgarage.php?do=popup&image=https://www.pro-touring.com/forum/vbgarage.php?do=getimage&id=172
