View Full Version : Transmission and rear end gear ratios
austinjjesus
01-07-2024, 11:34 PM
Hey guys, I’ve fallen into the trap of doing research on the internet. Im building (hear me out) an E36. I’ve got a mildly cammed 5.3 built for it and I’m probably going to end up going t10 since I have one readily available. And no I can’t afford a tkx or t56 :) so the t10 I have is a 2.64 first gear and the rear end in the car is a 3.91. I’m not worried about highway mpg because it’s pure track/fun car. I’ve read a lot of contradicting info that I can’t wrap my head around. I’m afraid it’s not going to launch hard and that’s really what I want first and foremost. Somebody help explain!! 211457
Little PFA ;)
Hotwire
01-08-2024, 06:39 AM
You can use this calculator to figure out your rpms and shift points.
https://www.blocklayer.com/rpm-gear
5.3s aren't know for a lot of torque so you'll have to put a little rpm to your launch but you should have plenty fun with it.
austinjjesus
01-08-2024, 09:49 AM
Thank you for this. The cam I have is advertised to make 400+ in a 5.3 but the car will probably weigh 2500 pounds ish with me in it. I’m just more worried about is being a pig because of the ratios. I’ll be honest, the combination of rear end ratio and trans ratios are way over my head lol
Mkelcy
01-08-2024, 03:08 PM
Rear tire size?
austinjjesus
01-08-2024, 04:00 PM
Rear tire size?
285/35/18
Mkelcy
01-08-2024, 05:02 PM
I've got an LS376/480, a 2.66 first gear T56 in front of a 3.70 rear end. My overall first gear ratio is 9.84, and I can light up my 295-35-18's all the way through first and second gears in a '68 Camaro. You'll be at about 10.24 overall first gear ratio in a much lighter car. I think you'll be fine.
austinjjesus
01-08-2024, 05:13 PM
If you don’t mind, can you explain the math behind that?
Mkelcy
01-08-2024, 05:17 PM
My combo - 2.66 x 3.70 = 9.842; your combo - 2.64 x 3.91 = 10.322. Our rear tire heights are about the same. I have more torque and weight, you're lighter with less torque. I think you'll be okay.
austinjjesus
01-08-2024, 07:26 PM
Ahhh understood, thank you
mmosley
01-12-2024, 07:27 PM
agree - you have a light car, the 2.64 will be just fine, it will also make for more time in first gear which is good for a track car. you also wont get as much rpm drop shifting to 2nd. This combo will be just fine.
austinjjesus
01-17-2024, 11:49 PM
Thanks for the input!! That also makes me feel better
