View Full Version : 550-934T Holley Terminator X Max MPFI Controller Kit $1500
need4speed069
01-02-2024, 08:47 AM
550-934THolley Terminator X Max MPFIController Kit
GMLS LS1/LS6 24x Tooth Reluctor
Note: Tocalibrate and tune a laptop is required to run the advanced tuningsoftware. For simple setup wizard and tuning without a laptoppurchase a kit that has the included 3.500 in. handheld touchscreen.
TakeControl of LS Swaps with TerminatorX MAX!
Features:
Simple Plug-and-Play engine controller for GM LS engines and will also control 4L60E and 4L80E automatic transmissions.
CAN/BUS Tuning Cable allows tuning with the use of a laptop computer (sold separately)
Real-Time Self-Learning fuel maps require no complicated tuning knowledge (Holley EFI software suite is included for advanced users with laptops)
On-board Multi-Color LEDDiagnostic allows quick troubleshooting on critical issues for ECU Power, Engine Running, Wideband Status, TPS Calibration, Crank Signal, Cam Signal.
Built-in 1bar MAPSensor with 1/8, 1/4, & 3/16 in. vacuum hose adapters included. For boosted applications, the internal sensor can be disabled to run an external LS style MAP sensor (not included) with terminated harness and connector (included).
4 Inputs - 12-volt, Ground, 5-volt, and Frequency can be used for activation triggers, trans brake, and to add extra pressure sensors.
4 Outputs - Ground and PWM can be used for electric fans, boost control, nitrous control, idle air control kit, and many more accessories.
Boost Controls - Ability to control boost vs time, boost vs. gear, boost vs. RPM, boost vs. speed, boost vs. safeties
Nitrous Controls - Single Channel Wet or Dry, Progressive or Non-Progressive, rich/lean safeties, and target closed-loop AFR
Advance Tables - 4x 1D Table, 1x 1D Gear Table, 4x 2D Table, 1x 2D per Gear Table. Can be used for custom tables for flex fuel sensor, fuel pressure safety, or oil pressure safety.
Bosch LSU 4.9 Wideband for precision reading and tuning control (will not function with LSU 4.2 oxygen sensors
High Impedance Injector Driver powers most GM stock LS and Holley EFI injectors. (Use of low impedance injectors will damage the ECU)
Holley EFI Accessories are mostly compatible (analog-style gauges, shift lights, and others.
PAYPAY ACCEPTED
SHIPPING INCLUDED
THISIS NEW IN THE BOX
BOXHAS BEEN OPENED TO INSURE ALL
COMPONENTS ARE ACCOUNTED FOR
CHECKOUT MY EBAY ACCOUNT ON EBAY
COXPERFORMANCEMOTORSPORTS
