View Full Version : Coilovers Making Noise
vaca828
12-26-2023, 06:28 PM
My driver side coilover has been making noise ever since I installed it. Only the driver side. There are rub marks on both sides of the coilover. I believe it is bottoming out.
211056211057
Mr Nick
12-26-2023, 07:57 PM
Yes, that's rubbing on something.
What is the application? is that a coil-over sleeve on a normal shock? Do you have ride height set lower than stock? if so, how much?
Pro Touring Store
12-26-2023, 08:02 PM
Find what it's rubbing, and remove material of that. If its rubbing the spring somehow... don't grind the spring though.
-Dale
dhutton
12-27-2023, 03:35 AM
Is the shock bottoming out? How low is the ride height? Is the shock roughly centered in its stroke at ride height? It needs to be….
Don
Senna
12-27-2023, 10:34 AM
I'll bet that it's rubbing on the frame, specifically the inside of the sping bucket.
