View Full Version : Cleaning up intake wiring. What’s the best way to mount wires to the intake?
70JUNk
12-15-2023, 01:04 AM
Here is how my alternator wire runs across my intake. Can anyone recommend a set up to bolt into my intake and tie the wires down to it. Please point me in a solid direction so I can have a clean looking run.
thanks!
Hotwire
12-15-2023, 04:36 AM
I usually run it out under the top radiator/ heater hose or run it along the oil pan rail and up around the bellhousing. No way to hide it on top of the intake..
210945
70JUNk
12-15-2023, 01:11 PM
Thats how it was routed previously, but i have a new front runner from vintage air, and I just want to see how others have secured the wiring to the manifold. I am sure there are some products out there, but I cant find it.
Hotwire
12-15-2023, 03:45 PM
Maybe get a piece of conduit, weld tabs to it, and paint it? Choose a color already in the engine bay or try to match the intake to help make it disappear.
79 Camaro
12-16-2023, 01:54 PM
It might mean you will have to lengthen the wires but the alt wires I would run low near where the oil pan bolts on the block with protection from the header heat and then come up from underneath to the alt.
I would extend the temp sensor so it runs in the same harness as the alt wiring and come up from underneath the alt.
Mr Nick
12-16-2023, 06:35 PM
A couple Adel Clamps using the valve cover bolts would be tidy and functional. That's how my wire harness was ran.
70JUNk
12-16-2023, 11:49 PM
I found that to be my solution. met up with the boys last night and my buddy Glen was like, use some adel clamps. Had a few lying around, now i just need a good looking bolt.
