View Full Version : 69 camaro door handles and latches
AUTODYNAMICS
12-11-2023, 09:18 PM
One thing I’ve always seen lacking is the upgrading of door latches (modern design) vs the old pieces.
At sema I looked over some builds ring brothers etc
They did swap out the latches, using a pt cruiser and strikes
Looking on how the oem handles work they will need some fab work to make them work with the rod style.
Anyone have any experience in this? I’ve seen Detroit speed do the same as well fesler
Any input ?? Thnx
CapSS92
12-13-2023, 01:22 AM
Tough as hell to do as they use cables versus the rod/lever style on the older cars. If you are going to swap, you're going to have to pull the latches as well and make them fit your door. Not saying it can't be done, just gonna require a lot of ingenuity. I've used the C6 electric door latch mechanisms on cars with shaved door handles and they work pretty well. I pop them open with a remote or interior button and they work just like a pop door. Cheap too.
https://www.ebay.com/itm/166389874769?fits=Year%3A2006%7CEngine+-+Liter_Display%3A6.0L%7CTrim%3ABase+Hatchback+2-Door%7CModel%3ACorvette%7CMake%3AChevrolet%7CSubmo del%3ABase%7CEngine%3A6.0L+5967CC+364Cu.+In.+V8+GA S+OHV+Naturally+Aspirated%7CSubmodel%3ABase%7CEngi ne%3A6.0L+5967CC+364Cu.+In.+V8+GAS+OHV+Naturally+A spirated&hash=item26bd9c0051%3Ag%3A3gYAAOSwHjJlNGk4&amdata=enc%3AAQAIAAABEMnFlBjClmkLbRO6mPK3DtDyBgr9s wKwOwnAV9z8PVykiNc3V%2FPwI%2FsNmVr%2Bmf6mGU%2BU72B jEsatW%2BJQVgOuZpsbN%2BWMXgjGTodsh3ufIDs631jlku0OX 0BWE3GFGrnBMp2tqAQdgYKSx1vCEreG%2Fz8GV90UYCKfjpynT tYGHS%2FbyExdmEKgSZieS5KWfq3KWuuxO0Lf5Bsnjc3w0VqmN nltqaxdjH17IGWM6%2BNIrwFJNawb%2FMWH%2BftfyeGm%2Bba Ug92qVx5ko8y%2BHWOYXp3XPhT8HekF5W1BVruE2CMF6jmBPHw UDihod5f5YNDdFPhsHx42ivW%2BdTaPBASwEubBfIJ5dbEw%2B AHT5KSj9hOCPXjY%7Ctkp%3ABk9SR4yQ3aeMYw&LH_ItemCondition=4
https://www.ebay.com/itm/314626685850?fits=Year%3A2006%7CEngine+-+Liter_Display%3A6.0L%7CTrim%3ABase+Hatchback+2-Door%7CModel%3ACorvette%7CMake%3AChevrolet%7CSubmo del%3ABase%7CEngine%3A6.0L+5967CC+364Cu.+In.+V8+GA S+OHV+Naturally+Aspirated%7CSubmodel%3ABase%7CEngi ne%3A6.0L+5967CC+364Cu.+In.+V8+GAS+OHV+Naturally+A spirated&hash=item4941363b9a%3Ag%3A0tAAAOSw499kelNh&amdata=enc%3AAQAIAAAA8FWT3qt5CSLeDPnm6eniA%2FhVgc6 SiPqlxJ1Gcn8AJ7PdR0y1o%2Fy8zR7wSN2m9J8KKp5VRjBb%2B KbWwIh9J%2F20V%2BI2ZYydAjgYlxpR839qZDFImQ7Zl2QcMMr OSYwLvXcDGYPQmBBc%2Fyr9i8YKH6luDDwEwkUr4QsIVpS%2F4 DcYvRUbJo4YIEXwxX%2ByB0mV9ueWUvP6UhOeJIOvvZHoG%2B0 FLxt%2Bxafd1pJsVAuhbtMCMuHu3jvT%2F1k7%2FEuJC07LZX3 7boKuKlT9aZs4AQ2u0kdDU9l4HVSm%2FvWJm0xGweti4P1lZnd ws95DdnxMHa4rbUA1SA%3D%3D%7Ctkp%3ABk9SR4qQ3aeMYw&LH_ItemCondition=4
Alex
slimjim
12-13-2023, 07:24 AM
I’m running 5th gen door latches and installed a rod-style door popper below it which will be triggered by a soft-touch actuator in the stock handles.
It isn’t finished yet, so at this point it’s just a plan.. but it will work
slimjim
12-13-2023, 07:30 AM
210929
210928
AUTODYNAMICS
12-14-2023, 06:24 PM
How are you operating the outer door handles ?
Are they stock?
slimjim
12-14-2023, 07:31 PM
Are they stock?
Yeah sorry I didn’t make it clear, inside I’ll use 5th gen door handles that are cable driven, but the exterior uses the 68 door handles which trigger the popper
