View Full Version : Poll: Anti-Seize or not on lug nuts / studs?
Larry Callahan
11-29-2023, 04:42 PM
What is everyone’s thoughts on using anti seize on lug nuts?
I have used it everything and people seem to be split on using it or not.
210729
SPLATT71MC
11-29-2023, 07:46 PM
I use the stick type anti-seize.
JustJohn
11-30-2023, 05:03 AM
Biggest issue is that lubricated threads do not reflect accurate torque values.
I check torque daily when the track car is being used and the wheels come off so frequently it is not an issue to keep the threads dry.
68Formula
11-30-2023, 10:03 AM
If you're properly torquing them to spec, you shouldn't need anti-seize IMHO. But if you're tightening method consists of counting the uggas uggas, then maybe it's worth it. I'd be considered with them loosening.
Tim C
11-30-2023, 03:24 PM
I vote no. I'm a mechanic, I get cars in where the lugs have antisieze and it turns sticky/gooey from brake heat. It actually makes the lugs harder to screw on or off by hand.
If I put anything on at all I put a small amount of wd40, pb blaster, whatever your penetrating oil of choice is on the threads. Usually only if the threads are rusted. 99% of the time they go on dry.
Pro Touring Store
12-01-2023, 07:58 AM
I put a very small amount on just to ease the thread-on. Some of the lug nuts out there don't have the best threads so I feel it helps. Especially important if you have Ti or Al lug nuts.
On a daily driver car that sees some moisture or corrosion (salt etc) I feel it's even more important. I have ruined several lug nuts and studs trying to get lug nuts off.
-Dale
srode
12-03-2023, 02:17 AM
Anit-seize is a lubricant and the torque spec for a lubricated fastener is lower than a dry fastener. For lug nuts the spec is dry (for any I have seen) so you need to reduce the torque if using Antii-seize. Their guidance is 25% reduction vs dry spec. Its messy so I don't use it on lugs. Steel fasteners into aluminum is the only place I use it really.
raustinss
12-03-2023, 07:46 AM
Absolutely wouldn't, will with the use of a daily car with aluminum rims against iron rotors
BK75
12-04-2023, 05:17 PM
I use it since I seem to remove my wheels more than any normal person, mainly to prevent thread galling.
JustJohn
12-05-2023, 04:54 AM
You should be treating lug nuts and studs as a wear item
cad
12-08-2023, 12:01 PM
Never on studs.... maybe on the back of a cast aluminum wheel hub. Only use sparingly on spark plugs, even though some mfr's supposedly take care of that.
Clark
RUTHLESSZ28
12-10-2023, 08:46 AM
As a 27yr. tech. i say no. if the threads are rusty a little penetrating oil or wire wheel to remove rust. ive seen too many times lugs come loose or studs stretched from over torquing.
