View Full Version : 1973 Camaro project
tsmitty999
11-07-2023, 06:38 AM
What up guy here is my 1973 Camaro I bought back in July, the car was already painted inferno orange. No motor no trans. 210382
210383
210384
210385
tsmitty999
11-07-2023, 06:52 AM
I already done quite a bit of things to it. I installed a hotchkis stage 2 suspension kit.
Borgeson quick ratio steering box.
Front Wilwood brakes 12.88”.
Us mags 111 18” wheels
nitto g555 245x40r18 front
285x40r18 rear.
5.3 with a mild cam, valve spring and piston. Ls6 intake
Hooker long tube headers
Holley mid drive kit
4l60e 210386
210387
210388
210389
210390
210391
210392
210393
210394
tsmitty999
11-07-2023, 06:53 AM
210395
210396
210397
210398
210399
210400
210401
210402
210403
tsmitty999
11-07-2023, 06:58 AM
Photo dump this is the current state had an issue with the holly mid drive power steering pump not having thread in the mounting holes. And just ordered a quick performance 9inch rear end housing and axles. 210404
210405
210406
tsmitty999
11-28-2023, 08:25 AM
I finally got the power steering pump from summit. the first one the mount hole were machine to big and missing threads. Mid drive is all done . Got my fuel line ran under the car and got the Holley fuel rails all connected. Steam ports are done. Got my quick performance 9inch housing and axle. Got it primed and painted. Just ordered a speed master third member with 3.70 gears for Black Friday.
210708
210709
210710
210711
210712
210713
ryeguy2006a
11-28-2023, 09:58 AM
That's the way to buy a project, fully painted!! Love the early second gens!
tsmitty999
12-01-2023, 08:06 AM
Yeah some of the hard work already done. Yeah 2nd gens are really cool I’m enjoying it.
tsmitty999
12-02-2023, 07:48 PM
Got a champion 3 core radiator mounted with custom work performance radiator cover installed 210778
210779
210780
210781
70JUNk
12-04-2023, 10:11 PM
awesome build!! I love the color. Same as my 2013 2SS Camaro.
tsmitty999
06-11-2025, 06:54 PM
Here a update it’s years since I’ve post on here but I’m basically done with the car. Just have a few little things and need to get my Holley terminator tuned. I had problems with the summit racing 4l60e with leaking and slipping. I ended up getting a 4l65e from gear star and haven’t had issues yet. 217427
217428
217429
217430
217431
217432
217433
217434
217435
tsmitty999
06-11-2025, 06:57 PM
217436
217437
217438
217439
217440
217441
217442
217443
217444
tsmitty999
06-11-2025, 06:58 PM
217445
217446
217447
217448
217449
217450
217451
217452
tsmitty999
06-11-2025, 07:01 PM
217453
217454
217455
217456
217457
217458
tsmitty999
06-11-2025, 07:02 PM
217459
217460
217461
217462
217463
217464
217465
217466
217467
tsmitty999
06-11-2025, 07:03 PM
217468
217469
217470
217471
217472
tsmitty999
06-11-2025, 07:22 PM
All the carbon fiber parts are from anvil auto. Have tmi products seats, acc carpet kit, retro speaker front pods, Rockford speakers, Pioneer DMH-WT3800NEX 9" head unit 217473
217474
217475
217476
217477
217478
217479
217480
rchaskin
06-12-2025, 02:15 AM
WOW, looks great!!
Gmachine1911
06-12-2025, 12:51 PM
Very nice ride! Congrats on getting it completed…looks fantastic!
ULTM8Z
06-12-2025, 01:58 PM
Dude, awesome build!!
I see you're in Burbank. Not too far from me. I'm headed over to Bob's Big Boy tomorrow... you should bring it by. Would love to see it in person.
Also would like to get more info on who did your rear seats and the custom console.
tsmitty999
06-12-2025, 05:15 PM
thank you. yes I'm in Burbank, I'll try and make it. I keep having issue with air getting trapped in the coolant, and it starts to overheating. So the backseat and console is made by TMI products. the back seat was just upholstery and i installed it on the original back seat frame.
ULTM8Z
06-12-2025, 07:25 PM
Just need to make sure to burp the system adequately. I typically let mine run with the cap off the radiator for a good 10-15 min after reaching full temp to make sure all the air is out.
jaybee
06-15-2025, 06:47 PM
Thanks for the update, that's coming out really nice.
c4racer2
06-18-2025, 09:01 AM
killer looking Camaro!!
tsmitty999
11-08-2025, 04:40 PM
Few New updates on the car so I was still having overheating issues after bleeding the air out of the cooling system. I changed the electric fans to spal 12” 1226cfm . I also switch the intake tube to an anvil auto carbon fiber intake tube. I was trying to get rid of the aluminum one thinking it was get Heat soaked. After change in those 2 thing it went from 235 f to 210-215f with the ac going. Another thing i also did was the radiator overflow tank hose kept blowing off when it got hot spitting out coolant. so I fixed that. Also changed engine closeout panel to anvil auto And a front splitter with cable splitter rods support struts and a carbon fiber wicker bill for the rear. also I start adding some custom trunk panels I still need to wrap them in vinyl. I have a new ride tech 4 link for the rear but I haven’t had a lot of time to install it yet. Been busy with work and other things on the car.
tsmitty999
11-08-2025, 04:44 PM
218900
218901
218902
218903
218904
218905
218906
218907
ULTM8Z
11-11-2025, 08:32 PM
215F is nothing for a LS. I know in the old days people used to consider that "overheating" with the small block Chevy's. Even now, with my 383 Gen1 SBC, if the temps start getting close to 200, I'll still get a tad bit nervous even though I know that's nothing either. Old habits...
But I think the LS engines are designed to run at those higher temperatures.
That said, your aluminum shroud may not be the greatest for moving air through at high speed... trying to shove a lot air at ~60mph through those relatively small fan openings. If you build up pressure in the shroud, it'll cause a restriction on trying to get more air through the radiator. I've seen where people (and factory shrouds) have moveable flaps in the shroud that will open when the incoming air pushes against them, thereby allowing more area for the air to get through.
Another possibility is that at low speed or at idle, the fans aren't powerful enough. ~1200 CFM per fan I take it? The two speed Ford Taurus fan I'm running will reportedly move ~2500 CFM on the low speed and ~4000-4500 CFM on the high speed. When the temp hits the high speed threshold, you can watch the temperature drop like a rock down to the low speed threshold.
I may try to hit Bob's Big Boy again on the 21st if the weather is good (supposed to rain like crazy this weekend). Bring the car so we can check this beast out in person!
Josh@Ridetech
11-12-2025, 05:46 AM
Awesome build. You've done an extremely good job, very clean work.
Kmart78
11-18-2025, 11:27 PM
Nice car! Are the rear seats TMI covers? Are you mini tubbed, and if so, did you alter the panel to fit or did it stretch enough to cover it?
tsmitty999
11-19-2025, 04:07 PM
yeah its been doing better but. i haven't driven it in about a month and half, but the weather is cooling down so i don't think it will overheating should be a issue. one thing it kept doing was when it would get above 225 it would blow off the overflow tank hose off and boil the radiator fluid out the overflow . but i did fix that. i still haven't been to bobs on friday night. i don"t think i"m gonna go this Friday with the rain.
tsmitty999
11-19-2025, 04:13 PM
Awesome build. You've done an extremely good job, very clean work. Thank you it’s been a lot work and a lot of time. I still have a brand new ride tech 4link I still need to install. Just need time to work on it. Do you guys still make the tigar cage?
tsmitty999
11-19-2025, 04:16 PM
yes it is a tmi cover. no i didnt mini tub it. i think you cut and narrow the frame, and take the the cover and just stretch it over it. but id check with tmi.
tsmitty999
11-19-2025, 04:21 PM
Finished the trunk panels219020
219021
219022
tsmitty999
01-11-2026, 07:36 PM
New update got new front suspension from ride tech for Black Friday though summit racing. Upper and lower a arms/ control arms, coil overs and front sway bar. I still need to change the inner tie rods and outer tie rods but Man I got to say what an upgrade the ride tech is over the hotchkis. It some much smoother and lot stiffer and overall more comfortable ride. I still need to install the ride tech 4 link but it been raining here in LA the last few weeks. 219469
219470
219471
219472
Beautiful car! That color looks so good on it:twothumbs
Josh@Ridetech
01-28-2026, 07:38 AM
Very nice! Thanks for the good words as well. We do our best to make these cars drive the way we think they should :cheers:
