View Full Version : Adding modern Camaro seats to old GM A body
LLL442
10-07-2023, 07:59 PM
I found this forum while trying to find some answers for putting modern seats in an old Oldsmobile. There was a thread from 2017 that sort of addressed my problem but left more questions than it answered.
I am in the early stages of building a 65 442. I live in Texas and have alway wanted cooled seats and vowed this car would have them. I now have a driver seat from a 2016 Camaro and a passenger seat from a 2018 Camaro. Once the mounting and wiring details are figured out I will eventually add the heating and cooling units when I reupholster them. Unfortunately these things have airbags in them. I am not comfortable just applying voltage to the wires to see what happens. The seats present different wiring. The thread I mentioned above was for someone working with 2016 Camaro seats. It was mentioned that if the user just wanted the adjustment to work then apply battery voltage to the RD-WH wire in pin 1 and RD-YE wire in pin 24, ground to black wire on pin 17.
This seemed to be my answer until I looked at the seat. The supplier thoughtfully removed the connector and there was a Red wire with yellow stripe and black wire that seem large enough to carry the necessary currnt (12 ga maybe). The rest are significantly smaller.
I don't mind working through connections until I find the right combo unless one of the wrong ones sets off the airbag(s). How do I make the adjusters work without blowing part of the seat out? And how are the airbags triggered? Seems like something to avoid.
Here is what I have to work with on the driver's side seat.
209627
I will address the passenger seat once this one is sorted out. It may just be a matter of applying voltage to the red/yellow and grounding to black on this one. But I don't know what causes the airbags to fire. Maybe I need to do something somewhere else to avoid that?
Any and all help is greatly appreciated.
Hotwire
10-09-2023, 03:20 AM
Go to your local Chevy stealership and ask if you can get the wiring diagram for 2016 & 2018 camaro seats. Usually you'll find a gearhead that will help you out. If not, google 2016 Camaro seat wiring diagram, always better to have the schematic to answer your questions. If there's wires in yellow sheathing, that's the airbag wires.
Usually with GM wiring Red is ignition, orange is battery, and black is ground.
LLL442
10-09-2023, 11:22 AM
Thanks. I appreciate the feedback. Especially the yellow wires are airbag wires. I was looking for the wiring diagrams when I came across this forum. I have had surprisingly bad luck at finding one. I will try the Chevy dealer when I get a chance. I haven't worked on anything where airbags were an issue and it makes me a bit nervous. I honestly don't see the yellow wires on this 2016 seat. I will have to try looking closer. This one only has the wires I show in the picture. At least that is all that dangles from the seat. Don't see any vacant connections. Maybe buried deeper than I am digging.
Thanks again. Glad I found this place. I will be doing a number of modifications and may be seeking recommendations or ideas as things progress.
csouth
10-10-2023, 06:11 AM
I had it the schematic at one point. Let me see if I can dig it up. Shoot me your email address or post it here.
