Parms22
09-29-2023, 01:50 PM
Hey Guys!
I have a 67 Camaro RS for sale on Bring a Trailer, check it out, full specs below:
1967 Camaro RS SS build
Motor and Transmission
-Era Correct 1967 Camaro RS SS stamped Block
-Magnafluxed and Honed block with new plugs
-396 Big Block Chevy Fully Roller and Forged internals- 556 HP
-March pulley bracket
-Edelbrock Performance Aluminum Heads
-Weisco Forged Competition Pistons
-Edelbrock Performer 2.0 Aluminum intake
-Comp Cams Full Rollers Rockers Aluminum
-Comp Cams Full Hydraulic Roller cam Stage 2
-Edelbrock 850 CFM Carb
-Meiling High Rate oil Pump
-SA gear billet timing set with torrington bearing and rolon chain
-Scat Crankshaft, clevite bearings, Balanced on CWT balaner to 2 grams
-Scat Competition rods with ARP 8740 cap screws
-Wiseco Premium forged pistons. 800+HP rated
-Melling Mselect series oil pump with m select drive
-Champ custom oil pan with oil control
-Prorace dampner.
-Brand new hood hinges
-MSD Digital Ignition and coil packs
-MSD Plug wires
- Detroit Speed Engine mounts
-TCI Street Fighter Turbo 400 Transmission
-TCI Street Fighter Torque Converter
-TCI Transmission mount
-TCI Dip stick
Cooling
- BeCool Aluminium Radiator with Derale Fans.
Body-
-Brand New exhaust 3 inch Custom X pipe with Magnaflow Mufflers
-Ricks Stainless steel Pro Touring Tank
-Ricks Tanks straps
-Walboro High flow fuel pump
-Brand New door handles, springs and locks
-Brand New Rear Chrome Bumper
-Brand New Front inner wheel wells
-Brand New Front Rad Support
-Brand New Complete Floor front and rear
-Brand New Inner rockers
-Brand New Front window moulding
-Brand New Rear window Chrome Moulding
-Brand New Internal Dash
-Brand New Outer Rockers
-Brand New Torque Boxes
-Brand New Rear Inner wheel wells
-Brand New Rear outer wheel wells
-Brand New Front RS SS Grill and window doors with actuators
-Brand New Front windshield
-Brand New driver and passenger front and rear windows
Interior
-Brand new Front Custom TMI Interior suede seats
-Brand new Rear TMI custom suede seats
-Brand new Front adjustable brackets
-Brand New front Seat foam
-Brand new front door panels
-Brand New rear Door panels
-Brand new Front and rear Black carpet loom
-Brand New Rear Tail light Lenses Chrome
-Brand New Dynamat Floor soundproofing
-Brand New rear Package tray
-Brand new glove compartment with hinges
Brakes
- Willwood Master cylinder and booster- anodized black
- Willwood 7 inch Brake Booster
- Willwood Forged Big Brake Front Brake Kit (https://www.summitracing.com/search/part-type/disc-brake-kits/product-line/wilwood-forged-dynalite-big-brake-front-brake-kits) 6 piston
- Willwood Forged Big Brake Kit Rear 6 piston
- Willwood 12.88 inch Rotors Front
- Willwood 12.88 inch Rotors Rear
- Willwood Brake pads low dust Front and Rear
- Willwood Proportioning Valve.
- Willwood Stainless steel brake lines.
Electronics
- Brand New speakers front and Rear, Installed in kick panels
- Brand New Kenwood Stereo
- Brand New American Autowire complete full harness
- Brand New Autometer GPS Pro Series Gauges
- Brand New GPS Speed sensor
- Brand New Optima Legend Battery
- Brand New battery wires and Terminals
- Brand New Front Oracle LED Headlights, High and low Beam
- Brand New RS SS Headlights and Doors and actuators-
- Brand New Light Bezels
- Brand New door handles, springs and locks, window cranks
Suspension-Ridetech Complete Coilover suspension Front Suspension
-Ridetech HQ Quality Dual Adjustable 650 lbs Front Coilovers
-Ridetech Upper and lower StrongArm Control arms
-Ridetech Upper and lower camber bolts
-Ridetech Upper and lower Ball joints
-Ridetech Billet Hubs Left and Right
-Ridetech Inner and outer tie rods
-Ridetech Rear 4 link system
-Ridetech HQ Quality Dual Adjustable Rear Coilovers
-Ridetech Rear Sway bar
-Ridetech Axle mounting brackets
-Ridetech Billet Tie Rod adjusters
-Ridetech Front muscle sway bar
-Ridetech Front Steering knuckle
-Ridetech Front Steering pitman Arm
-Ridetech Lifetime Adjustable Sleeves L and R
-Ridetech Tru Turn upgraded Steering
-Ridetech Sub Frame Connectors Powder coated Red
-Complete 12 Bolt Moser Custom Rear End
-Stranger 37 Spline axles
-Posi Trac Rear
-Auburn 3.73 gears
-Moser Rear end 12 bolt cover
Wheels and Tires
-Custom 18x8.5 Front Rally wheels
-Custom 18x9.5 Rear Rally wheels
-Chrome Center wheel caps
-Wilwood Lug nuts
-Wilwood Locking nuts
-285 Rear Brand new tires
-255 Front Brand new tires
-Prorace dampner.
-MSD Plug wires
-TCI Dip stick
Cooling
Body-
-Ricks Tanks straps
Interior
Brakes
Electronics
-Posi Trac Rear
-Auburn 3.73 gears
Wheels and Tires
-Wilwood Lug nuts
