sshedley
09-28-2023, 09:16 PM
Hi All,
Really excited to be able to access this fantastic community here.
First off I'm trying to find a front brake solution for my 67 Camaro. I've installed the brand new Global West upper & lower control arms, using my stock disk brake spindles.
I have in stock Holden HSV (Holden Special Vehicles) Clubsport PBR calipers which are identical to C5 C6 calipers. I have also the 325mm x 32mm rotors. I was going to just get the C5 conversion hub adapters to slide onto my stock disk spindle.
I've found the CPP C5 Spindle stock height(advertised with a 1" drop though, and I already have tall upper ball joints), which will then require a C5 C6 or C7 hub to bolt on.
Other option is the AFX Spindle from Sppedtech i believe, but I think my stock steering arm needs changing then too??
Any recommendations for or against the CPP spindle adapter? I'm thinking it's the easiest, just unsure about its quality?
I want to use the car around circuit tracks when we move back to Perth at the end of our country stint.
Hopefully these questions can be answered here, if not I'll create another post/ topic.
Cheers!!!
Cheers!!!
