View Full Version : 1970 Camaro project car
mdes0
08-17-2023, 06:55 AM
70 Camaro project car, has Detroit Speed and Engineering (DSE) hydroformed front subframe assembly including corvette spindles, coil overs, and rack and pinion steering, DSE firewall block off plate, DSE brake and clutch support bracket, DSE solid aluminum body mounts, DSE weld in frame connectors, DSE four point roll cage, DSE rear four link (quadra link) with coil overs, and DSE mini-tubs. Rear quarters have been flared about 2". Replaced drivers quarter, outer wheel wells, trunk floor, drivers side drop off, and rear tail panel. Comes with new AMD front fenders plus the originals, two hoods and two trunks. Core support and front nose assembly and all hardware included. Has a 12 bolt rear end with 4:11 gears. Sitting on a set of Corvette Grand Sport C6 wheels, one is bad. Have the original seats and center console. Also comes with a set of seats from an Infiniti G37 that I planned to put in. Comes with DSE LS motor mounts, can be changed to support what ever motor you want to use. Build thread listed under Project Wicked Pissa. $25k obo. Located in Brookline, NH208805208806208807208808
mdes0
10-02-2023, 01:01 PM
Sold
