dduke2
08-08-2023, 01:05 PM
1968 Camaro all steel body with clean 1968 Camaro Texas Title in my name.
$90,000 obo. Car located in Houston Texas
1000+ WHP
DM for more info.
ENGINE & TRANSMISSION
Engine Built and assembled by LME
GM Bow Tie LSX race block
Callies Dragon Slayer 4340 forged 4.0" stroke crankshaft w/Indexed & Trued Journals
Callies Ultra Billet 6.125" H beam rods w/ARP ULTRA 7/16" bolts
Wiseco/LME Custom Forged Pistons w/Upgraded Heavy Wall (.200")Tool Steel Wrist Pins & Anti Friction Coating On Skirts: Includes lateral Gas Ports & Double Pin Oilers.
NPR GFX Stainless Chrome Top Ring
Clevite MS 2199 H mains, Clevite CB 663 H rods, Dura Bond CH-23 cam bearings
ARP Pro Series 12pt. main stud kit
MAST/Performance Induction Black label 285cc LS7 6 bolt CNC ported cylinder heads: 2.200" Titanium intake valves w/coating on head, Inconel 1.600" exhaust valves
Cam Motion custom LS1 camshaft
Roll master double roller timing set w/ Torrington bearing and nitrated gears
Comp Cams Hyd. Roller Tie Bar Short Travel Race Lifters
Smith Brother Three Piece Ball in Ball 3/8" x .145" Heavy Wall Pushrods
Crower Pro series Shaft Mounted Adjustable Rockers Arms
Cometic MLS 6 bolt head gaskets
ARP 2000 Pro Series 12 pt. head studs for LSX 6 bolt block
Melling 10295 high pressure, coated oil pump/ ported
GM LS2 front cover w/ cam sensor, gasket, seal, and bolts
GM LS2 valley cover w/ gasket and bolts
Moroso sheet metal aluminum oil pan w/ billet rail, full length windage tray & custom pick-up tube.
Tall Billet Valve Covers with Coil Bosses/Billet Oil Fill Cap: Includes Stainless Hardware & Gaskets
102mm Nick William billet drive by wire throttle body w/electric motor
BOSH 2000cc Injectors
ATI SFI F-body balancer w/ A/C pulley
LME Billet Intake
Procharger F2 Transplant Kit
Dual Red Race Valves
MSD Starter
Rossler Terminator 4 4L80e with Transbrake
Yank 3400 convertor
Stainless American Racing Headers 2 Primaries
3.5 Magnaflow Race mufflers
REAR SUSPENSION
Detroit Speed & Engineering Quadra Link
Detroit Speed & Engineering Quadra rear tow hooks
Moser 9 Ford with 370 Tru-Trac
Moser 35 spline axles
FRONT SUSPENSION
Detroit Speed & Engineering Hydroformed subframe w/rack and pinion
Detroit Speed & Engineering Adjustable coil overs
BRAKES
Baer 6 piston 14 Front 2 piece slotted
Baer 6 piston 14 Rear 2 piece slotted
Baer Black Master Cylinder
Baer Black proportion valve
WHEELS & TIRES
Boze Front 18x10 with Nitto NT05
Boze Rear 19x12 with Nitto NT05 345/30/19
Boze Rear (Spare) 18x10 with Mickey Thompson Drag Radial
INTERIOR
Infinity Box 10 circuit Wiring System
Infinity Box inTOUCH Net
Infinity Box inMOTION
2015 Camaro ZL1 Seats (Motorized and heated)
Flush mounted Ipad (Ipad runs Infinity Box)
Momo Steering wheel
Holley Digital dash
Push button start
Nu-Relic Power Window kit
Dual Billet Aluminum Optima Battery Trays
Dual Red Top Optima Batteries
Ring Brothers Billet Door Vents
Ring Brothers Billet Door Floor Seal Plates
Aluminum glove box
EXTERIOR & BODY
Fesler Flush Mounted front and rear glass
Mini Tubes
Smoothed Firewall
69 Camaro Valance panel with LED Fog lights
2 Cowl Hood
Custom built Rear Spoiler
Felser Billet Tail lights
Digi-Tails LED Sequential Tail Lights
Fully Dynamat including door and roof
Billet LED Turn Lights
LED Driving Lights
Ring Brothers Billet Door Handles
Ring Brothers Billet Hood Hinges
Ring Brothers Billet Hood Pin Kit
1000+ WHP
DM for more info.
LME Billet Intake
MSD Starter
Yank 3400 convertor
REAR SUSPENSION
FRONT SUSPENSION
BRAKES
WHEELS & TIRES
INTERIOR
Momo Steering wheel
Holley Digital dash
Push button start
Aluminum glove box
EXTERIOR & BODY
Mini Tubes
Smoothed Firewall
2 Cowl Hood
LED Driving Lights
