View Full Version : 1969 Camaro Pro-touring project car and parts package
jwcarguy
06-30-2023, 09:41 AM
I am considering selling one our 69 Camaro project cars, that I am planning on building a pro-touring car
The car is for sale, but NOT on sale! price is firm
If it doesn't sell, I will just move forward and build it
Attention Keyboard appraisers!! Please try and control yourselves, if you have nothing good to say, please just keep on scrolling past my ad!
Only selling as a complete package with all parts, will NOT respond to questions about if parts or just car is available
We bought this car from a professional body man that was building it for himself
Car body is rustfree and has a ton new sheetmetal installed (AMD) Quarters, roof. floors, trunk, doors, fenders
Car has a "12337" VIN #
Body and over $46,000 in Parts:(not including shipping and taxes, the majority of parts are new or mocked up, none are installed on car now, besides front frame / suspension is assembled)
69 Camaro rust free body ONLY (clean / clear title) has new quarters, roof, trunk, floor pans, doors, fenders, inners, upper dash (was told all AMD), w/rear seat, factory dash, no a/c ,has original no spoiler trunklid, tail panel, dash, firewall, GM original SS hood ( no cowl hood, it was changed out)
extra original cowl vent panel
extra NEW AMD header panel, original one car has small dents
Car is currently on a dolly (not included), no frame or rearend/ wheels are in it now, pics are when we picked it up
Body Parts:
After market fiberglass inner wheel wells front $150
Full set restored/polished GM front & rear window trim sets $1,000
Restored original GM drip rail molding set $250
New Repo black standard grill w/2 stiffeners $300
New headlight bezels black w/ chrome $100
Marquez fiberglass front smooth tucked bumper $400
Marquez fiberglass smoothed tucked rear bumper $500
New rear spoiler $125
New F & R chrome bumpers $300
SS hood inserts, chrome & black $250
Shark skin hood inserts $55
Billet subframe bushing kit $120
Front sheet metal hardware kit (2) $130
Marquez Billet tail light bezels STD design w/ backup lens $300
Dapper Lighting Billet front fog/park/turn signals black $300
Fesler Billet hood latch $150
Digi tails LED tail light kit $275
II Much Fabrication fuel vent $250
DSE Mini Tub Kit $430
DSE Stainless steel narrowed efi fuel tank kit w/ sender $1100
Holley 450lph EFI in tank fuel pump kit $715
Interior Parts:
OER Black carpet kit $175
Black A/C dash pad $400
Extra glove box door, dash grab handles & plate $200
TMI suede A-pillars $100
NOS black center dash vent unit $130
Marquez fiberglass & mesh rear package tray $150
"1976Camaroguy" Dennis on P-T.com (https://l.facebook.com/l.php?u=http%3A%2F%2FP-T.com%2F%3Ffbclid%3DIwAR34l-JKjgjXKjy5G4P0TMeTfD57DAH5scXCOk3q-ZGX-P8-QHJCr_4qC60&h=AT3DRPQ0dmVxiyOtsDdx_ExzOEd14QMD-WqDJt51W2MTuUZ_DfjMNMdBc9AHZxTwc01dgURor3TuNkEf-yxGXFeJVUZSVCUaOf3Vw6PLY1fETSpHZM2TcW2GB0T566cEaj-K&__tn__=-UK-R&c[0]=AT1s_62bMoNxwQ6N5kXK8UsZI8lkToKiblRDxj3Bttjem9mwg VZJ35cs1WmaWl1HwrSywaQKD4NOzs1utwwl3Sl4O2FNT4kY--8rLre_fQ21cZbTkWNKdX4MKoddyBMMC2RH76VE3Y9utrOQxd65 80lIB4RQkKXzZ1Es7HY1VeLI2UhJB-LNUyJiFEhZuRPfoFDGV4j2qPtYv-TtcAfkfyOOnHHxZUtTjrRrcg-fIQ) custom fiberglass package tray w/3 mdf inserts $190
"1976Camaroguy" Dennis on P-T.com (https://l.facebook.com/l.php?u=http%3A%2F%2FP-T.com%2F%3Ffbclid%3DIwAR0dO61HD3-JGUkgktzkcsmxQlUjnzJlKbSuXVneoaeW9FVZtycDkwXjkdA&h=AT3DRPQ0dmVxiyOtsDdx_ExzOEd14QMD-WqDJt51W2MTuUZ_DfjMNMdBc9AHZxTwc01dgURor3TuNkEf-yxGXFeJVUZSVCUaOf3Vw6PLY1fETSpHZM2TcW2GB0T566cEaj-K&__tn__=-UK-R&c[0]=AT1s_62bMoNxwQ6N5kXK8UsZI8lkToKiblRDxj3Bttjem9mwg VZJ35cs1WmaWl1HwrSywaQKD4NOzs1utwwl3Sl4O2FNT4kY--8rLre_fQ21cZbTkWNKdX4MKoddyBMMC2RH76VE3Y9utrOQxd65 80lIB4RQkKXzZ1Es7HY1VeLI2UhJB-LNUyJiFEhZuRPfoFDGV4j2qPtYv-TtcAfkfyOOnHHxZUtTjrRrcg-fIQ) custom fiberglass kick panels, w/mdf speaker inserts $150
Frank’s "1969CamaroSkunkworks" Gray Area Products aluminum kick panel set $700
Ididit tilt steering column raw $925
Ididit Billet lower firewall column mount $130
Modo pedal pad kit $150
Rag joint for column $100
6 speed console plaque $40
Momo “Retro” leather steering wheel $220
Alpine X-A90V amp $550
AAW classic update wiring kit #500686 $845
DSE dash w/Autometer Phantom gauges, VA controller, Alpine single din head unit, side vent $2,000
1 Ridetech 5pt. Harness $120
NRG Hub & quick release $250
Engine & Drivetrain:
Magnum 6-speed transmission $3,500
McLeod RXT clutch kit w/steel fly wheel $1270
Hurst Blackjack 69 Camaro Magnum shifter kit $550
S1 Sequential Magnum shifter kit w/indicator $1,800
Holley LS swap oil pan 4.25" stroke $350
Speedway LS Dry Sump oil pan $200
Fast 102mm LS7 Intake manifold w/ bolts, injector spacers $1250
GM LS7 rear cover kit $140
Strange 9” nodular center section/ third member Daytona pinion, 1350 yoke, Eaton Tru-Trac posi 4.10 gears (200miles) $1,800
102mm DBW Throttle Body black $180
LS7 Valve covers $100
Black LS valve covers w/coils & Billet relocation mounts $300
Frank’s "1969CamaroSkunkworks" Gray Area products aluminum cold air intake tube $300
LS7 MAF GM/ Delphi $100
Tick adjustable clutch master cylinder kit & Speedtech clutch master cylinder firewall bracket $400
Billet clutch reservoir $75
Chassis:
Built front subframe built w/Ridetech upper and lower Arms, Adj Coilovers, MuscleBar front sway, Tru-Turn kit w/ spindles, Turn One/DSE 12:1 steering box, Speedtech T56 Crossmember , powdercoated $5,600
Holley engine & T56 mount / crossmember kits $650
Comp. Engineering Roll bar kit $200
Ridetech rear 4-link kit w/Ridetech coilover shocks $2,700
new Ford 9” housing & 31 spline axles, Torino ends, w/Ridetech brackets $1,800
Brakes:
Front Wilwood #140-9804-D 6 piston Superlite Calipers, blk, 14” Drilled/ Slotted Rotors $2,500
Rear Wilwood #140-9219-D 4 piston Superlite Calipers blk ,12.88” Drilled/ Slotted Rotors $2,180
Wilwood Master Cylinder $250
Wilwood Proportioning valve kit $140
Hydra Tech Hydro-boost setup w/ SS line kit $1,130
Wilwood SS Brake Hose set $80
Wilwood Emergency Brake Cable kit $150
Plus boxes of alot of misc and small items and hardware, both new and used
Selling the 69 Camaro body with title and all parts listed above as a package I WILL NOT separate, so please don't ask! again, we don't have to sell this, will keep and build if it doesn't sell
$65,000 firm
I can send additional pics to serious buyers.
in Las Vegas, NV
