    Results 1 to 6 of 6
      Dec 2020
      69 Firebird axle centreline
      Not sure if I’m posting in the right location.
      I have a 69 Firebird with a ridetech 4 link. My cradle is not tight to the frame rails. There is about 1/4 inch of movement. I’m running an LS that is centred in the subframe and my question is, where is the axle pinion yoke supposed to be located? If I try to centre it the axle is to far to the driver’s side and if I offset it about 1/2 to the passengers side the driveline will not be centred. The driveshaft will be on an angle.
      Any help with this will be greatly appreciated.
      Thanks.
      Jul 2021
      Gig-Harbor, WA
      It is my understanding that stock Pontiac blocks and 10/12 bolt rearends are offset by 1/2 inch. I cant speak to an LS block, but believe theyre centered as you stated. Did you purchase the rearend with the 4 link brackets already welded on? What type of rearend is it? It seems to me that your only option at this point to correct it is to fix the bracket location on the housing, otherwise you will have no choice but to go with the 1/2 inch offset. I am in the middle of installing the same thing on my 68 firebird. I am looking into a quickperformance ford 9 inch, but imagine I will get by with stock positioning due to having a pontiac 400.
      IL/TN
      GM 10/12 bolt have the pinion offset 1/2" to the right.
      https://www.protouringf-body.com "doing what they say can't be done"
      Sep 2004
      Santa Barbara, Ca
      The guys at Currie told me they build all their 9” housings with a 1/2” passenger side offset. I think they said they do this even with the engine centered to give the u-joints some operating angle.
      Andy
      1967 Camaro RS
      Magnacharged LS1/T56
      543 rwhp, 516 rwtq
      Sold
      1968 Firebird
      LS427/570 and T56 Magnum
      Feb 2019
      Easley, SC
      You don't use the pinion as a center dimension. Always use the axle flanges / wheels etc.
      -Dale
      Pro Touring Store: Your parts source for all things Pro Touring! We have the best prices & service from suspension, to crate engine packages, to billet accessories and much more!
      www.ProTouringStore.com
      (Not affiliated with Pro-Touring.com)
      Dec 2020
      Thank you everyone. The help and info is greatly appreciated. Got the axle dialled In where it needs to be with the pinion 1/2” offset.
