Hooded
04-02-2023, 06:51 PM
I first want to thank everyone on this website! It was a fun four years finding the right setup of parts, but time has come to sell my 1968 Camaro. It was bought as a unfinished Rally Sport project, currently has 4K miles on the LSX376-B15. Only issue with the Camaro is it needs Paint and Body. Here is the build list below:
Asking 70K
Interior Components
1968 Camaro Black Deluxe Interior
Gentex auto dim rear view mirror with Homelink and compass.
Dash & Console Components
Ididit Steering Column
Dakota Digital RTX with Center Console Gauges
RetroSound Hermosa Bluetooth Radio and Microphone
Body Components
1968 Chevrolet Camaro Rally Sport
Full registration up to date
Needs Paint and Body Work!
Detroit Speed Mini Tub Kit
Bowler Transmission Tunnel (Tremec Magnum Clearance)
Detroit Speed Rally Sport Headlight Kit
Digitails LED Tail Lights
LED Headlights
Nu Relics Four Way Power Windows
Modo Trunk Lock Solenoid
Modo Power Lock Actuators
Raingear Hidden Wiper System
Steering, Suspension, Rear End & Brakes
Powdered Coated Stock Subframe with Notches for AC compressor and alternator
BMR Bolt In Subframe Connectors
Speed Tech High Clearance Upper Control Arms
Speed Tech Lower Control Arms
Speed Tech Chicane Coil Over Shocks with Viking 550# Pound Springs
Speed Tech Sway Bar
Speed Tech Body Bushings
Unisteer Steer Power Rack and Pinion
Unisteer Steering Shaft U-Joint Kit
Power Steering Cooler
Speed Tech Torque Arm Suspension
Viking Rear Coil Over shocks with 175# Pound Springs
CTSV Power Steering Pump
Power Steering Pump Volume
Power Steering pump Pressure Reducer Kit
Quick Performance Ford 9 Inch
31 Spline Axles
Yukon Trac Loc Differential
Motive Gear 3:89 Rear Gears
1350 Mark Williams Yoke
MotorSports Innovations Holley DS Kit 16 Lug collar Driveshaft Sensor
Rushforth Black Widow 18 x 9 Front Wheels with 5 3/8 back spacing
Rushforth Black Widow 19 x 11 Rear Wheels with 7 1/4 back spacing
Nitto 275 45 18 NT05 front tires
Nitto 305 30 19 NT05R Rear tires
Detroit Speed Brake Booster and Master Cylinder
Baer Adjustable Proportional valve
Hurst Line Lock Solenoid
ATS Spindle C6 Brake Kit from Kore3
Rear Brake kit C6 with Parking brake from Kore3
A/C, Heater & Cooling System
Chevrolet LSA Water Pump
Dirty Dingo Low Mount AC Combo Kit
Vintage Air Sure fit AC System
C&R Radiator with Oil and Power Steering Cooler
C&R Intercooler for Supercharger
2015 Zl1 Camaro Intercooler Pump
Engine & Components
Chevrolet LSX-B15 Crate Motor
Chevrolet LSA Valve Covers
Holley 302-1 Oil Pan
Chevrolet LS3 Coil Packs
MSD Spark Plug Wires
NGK Spark Plugs BR7EF
Chevrolet 2015 Camaro ZL1 Alternator
ATI Balancer
ATI Balancer Supercharger Pulley 7.48”
Chevrolet 2015 Zl1 Camaro Front Drive Setup
Magnuson TVS2650 Magnum LSA Hot Rod Supercharger Kit
DeatschWerks 90 lb/hr Fuel Injectors
Magnuson 120mm Air Inlet
Nick Williams 112mm Throttle Body
Frank’s Pro Touring Cold Air Intake
Fuel & Exhaust
RideTech Black Gas Cap
Tanks INC Notched Fuel Tank
Walbro 450 lph Hellcat Fuel Pump
Tanks INC 90 Sending Unit
Vibrant PTFE -8 Fuel line (Both Source and Return)
II Much Fuel Vapor Filter
Holley Fuel Pressure Regulator with Boost Compensation
Ultimate Headers Custom 1 7/8 Headers with Grey Ceramic Coated
Custom Full Length 3” inch Exhaust with H-pipe from ED Hanson
Flow Master two chamber mufflers
Transmission, Shifter & Clutch
Tremec Magnum (2.66 First Gear)
McLeod RXT 1200 Twin Clutch Kit
Quicktime Bellhousing
Lakewood Bellhousing adjustable dowel pins
LS1 Slave Cylinder
Holley Blackjack Hurst Shifter
Modern Driveline Hydraulic clutch master cylinder kit
Speed Tech Transmission Crossmember
Batteries & Wiring
Dakota Digital TPMS sensor Kit
American AutoWire 1968 Camaro Wiring Kit
Dakota Digital Auto Headlights with Accessory Power Retain
Optima Red Top Battery in Trunk with Inline fuse protection
Holley Dominator ECU
Holley Power Harness
Holley LS2 Main Harness
Holley Drive by Wire Harness
Holley 2nd wideband O2 Sensor Harness
Asking 70K
Interior Components
Body Components
LED Headlights
Speed Tech Sway Bar
31 Spline Axles
Engine & Components
ATI Balancer
Fuel & Exhaust
LS1 Slave Cylinder
Batteries & Wiring
