Monte_ExpreSS
02-18-2023, 07:16 AM
Anyone here running Spal Brushless fans with their sbl-ts temperature sensor? I bought a set of the 12” fans from dewitts. The temp sensor includes a 12v override wire that can be used to run the fans on high speed. I tied that into my a/c pressure switch.
When the vehicle is cold, running or just key on the override turns the fan on high. If I let the car come up to temp, the fans kick on, gradually ramp up speed and cool the car off. Problem Im having is it only works 1 time!! Once they cycle one time, they never turn on again. I have to wait for the car to fully cool off before they will restart.
For testing purposes, I bought a second sensor to try, but it didnt change.
I have the main power for the fans ran to the alternator stud as my battery is mounted in the trunk.
Confirmed 14.2v at power source for fans, and all other connections are soldiered and heat shrinked.
Spoke with Brent at Spal, and he suggested powering the fans directly to the battery. Tried that as well but no change.
Not sure where to go from here.
https://www.dewitts.com/collections/brushless-fans/products/dewitts-dual-12-brushless-fan-kit?fbclid=IwAR2vN0mTdq8M928_Anitf9FX7LraFXt6JgwLC ecllVDGeFJylSxxz43W5Cs
