slowcamaro
01-10-2006, 10:02 AM
My friend just swapped a gforce t5 into his 65 stang. Now he can't find a set of headers that will fit with his Mcleod scattersheild.
Does anyone know of a set that will fit? Heres his combo:
Engine: 347ci stroker, Edelbrock RPM aluminum cylinder heads, Edelbrock RPM aluminum intake, Edelbrock Cam and lifters .496"/.520", Comp Cams double roller timing chain, Scorpion 1.6 Roller Rockers, Edelbrock hardened pushrods and guide plates, Probe forged pistons, Eagle 5140 I-beam Rods, Eagle crank, around 10.5:1 CR, Canton Windage Tray, 7qt T Sump oil pan, Melling HV oil pump, Holley 670 Street Avenger, Holley fuel pump
Transmission: G-Force T-5 (600hp/500ft.lbs), Pro 5.0 shifter, Fidanza Aluminum Flywheel, Center Force Pressure Plate, Mcleod Disc, McCleod Scattershield
Thanks in advance
-blyth
Thanks in advance
-blyth
