View Full Version : LS3 Radiator Fan Controller
Zombie666
02-06-2023, 03:18 PM
I have an LS3 in my 68 Chevelle. I’ve installed dual radiator fans. I know the engine control box has an output from a 50A fuse. Can you through the computer have a dual fan setup or do I need a aftermarket controller to ramp fans up and down, OR, just wire up the fans to both come on at the same time, OR, just go to one big fan. Thanks I’m advance.
perry
dhutton
02-06-2023, 06:35 PM
You can wire it so they both turn on and off at the same time but it will be noisy. A PWM fan controller from Northern Radiator or DC Controls will be a lot quieter and not have big on/off current spikes.
Don
streetk14
02-09-2023, 07:28 AM
What’s controlling the engine? If it’s a factory GM ECU like an E38, you can use an OEM fan controller. I have a C6 Corvette controller on my car, but this is only for smaller fans. There are options depending on your setup and cooling needs.
TANKMASTERJ
02-09-2023, 05:52 PM
Here's a plug for autocoolguy.com.
I have one of his controllers. Variable technology, program to whatever temp you want. It throttles my twin fans well. Stays running after you lil the engine for a set time.
Has a bypass w
Switch you can add to default to high on in the event of a controller failure or a very hot event for whatever reason.
I'm 700hp NA and at 110 outside temps my temp is steady. Also has trigger for AC input and out205338
marolf101x
02-09-2023, 06:31 PM
If you'd like to send the controller a PWM signal from the engine computer to ramp the fan speed based on whatever you program in the engine computer you can use this:
https://creativewerksinc.com/product/pwm-controller/
Or if you want to use a temp sensor (1/8" NPT, 3/8" NPT and metric options) you can use it too.
You can set it up via a programming cable, or it can be pre-configured and shipped ready to go.
dhutton
02-10-2023, 05:37 AM
That is a pretty cool part.
Don
marolf101x
02-10-2023, 06:05 AM
It also has a CAN chip onboard so you can just pull coolant temp off the bus so you don't need a sensor.
However, the software is not quite finished.
slazisme
02-13-2023, 04:46 PM
Not to sidetrack from the original post......will this product work with brushed fans? If yes, could you also run this from a GM temp sensor welded above the lower rad hose for a non ECM fan control? TIA.
marolf101x
02-13-2023, 06:07 PM
Yes, this controller is designed specifically to run brushed motors (fans included).
Yes, you can run a fan cooling strategy independent of an engine control computer with a stand alone temp sensor.
The software is configurable via a PC app (or it can be pre-programmed if you don't want to screw with it).
It has options for 3 temp sensors. You just tell it which sensor you are using.
CWI VDO type temp sensor: 1/8 NPT threads
GM part number (AC Delco part number): 3/8 NPT threads
12146312 (213-928 )
25037332 (213-77)
15326386 (213-928)
GM part number (AC Delco part number): M12 x 1.5 threads
15326388 (213-333)
12608814 (213-4333)
19236568 (213-4514)
