67L88Vette
01-29-2023, 10:10 AM
Up for sale is a nice used Be Cool radiator for many of the full size GM trucks and SUVs. This is Be Cool part number 66069, and has a 40" wide body (tank-to-tank), a 32" wide X 17" high core, and a 3" end tank thickness with a 2" core thickness. It features two 1" wide rows in it for great heat transfer, and has 1.25" inlet pipe on the upper driver side, and 1.5" outlet pipe on the lower passenger side tank. It has a auto trans cooler built into the passenger side tank, and an engine oil cooler built into the driver side tank. This is a direct fit replacement for the radiator GM used in many of its heavy duty cooling optioned trucks, such as the 7.4L powered ones. I had it in my '92 7.4L C1500. The rad is in good condition and is corrosion and electrolysis-damage free. I used high quality Amsoil radiator coolant with RMI additive to manage the pH of the coolant. I will include the two engine oil cooler adapter fittings I used to connect my custom made oil cooler hoses that used AN fittings. I got tired of the GM crimp lines eventually leaking. I'll also include a good used 16lb radiator cap. The rad will be carefully packaged for safe shipment. This radiator sells for over $900 new. Great rad for you guys with the 88-98 GM Truck/SUV tow vehicles. Asking $450 shipped to your door in the lower 48 United States. Thanks for looking!
John A, 67L88Vette
20505220506020505920505820505720505620505520505420 5053205061
John A, 67L88Vette
