View Full Version : Mounting LSA Intercooler Pump - 69 Camaro
samvera31
01-17-2023, 09:18 PM
Hi everyone - can anyone share pictures or ideas of where y’all are mounting your LSA supercharger intercooler pumps on a 1st Gen Camaro? Trying to get ideas since I’m running out of real estate given I’m running both a power steering and engine cooler in the front along with a Vintage Air system.
Thanks!
Bobsky
01-22-2023, 12:15 PM
I've got an LT4 build going on now. I would suggest simply looking for available real estate, depends if you have a reservoir to plumb near as well. Pump location can be quite flexible though... Look up V8 Speed and Resto shop for their LT4 builds if you want some good pictures.
joeko23
01-23-2023, 05:18 PM
Take a look at my build, page 12 post 222. I used the stock zl1 intercooler pump and stock hoses. I flipped the zl1 intercooler pump bracket. You want that pump to be as low as possible.
https://www.pro-touring.com/threads/125828-69-Camaro-RS-LSA-TR6060-and-0-Fab-Skills/page12
Senek67RS
01-25-2023, 09:00 AM
I am at the same point and decided to mount it low on the passenger side of the core support. I am also putting an expansion tank directly above as a fill point, then using the push lock adapter that fits on the front of the lid that LSX Innovations makes that also has a small fill cap to ensure I can get all of the air out of the system.
samvera31
03-20-2023, 06:50 PM
Sweet a$$ Camaro!! where did you get that bracket from? Looks custom made?
- - - Updated - - -
joeko23
03-22-2023, 05:16 PM
It’s the stock ZL-1 12-15 intercooler pump bracket.
cwylie
03-30-2023, 06:22 AM
I built a new hood latch support and mounted it on that. It's about as low as you can get it.
Senek67RS
04-10-2023, 12:30 PM
Looks sweet and great idea! No issues with the heat exchanger, in terms of clearance?
