View Full Version : 1st gen camaro upper coilover 1/2 bolt eye conversion
darkostoj
12-23-2022, 08:16 AM
Hey!
Got a 67 camaro with a factory subframe and want to put on coilovers with a 1/2 upper bolt.
Anyone know if there is a company out there that makes brackets I can weld on?
Thanks!
BuzzKillian
12-23-2022, 09:18 AM
I got some brackets from RideTech.com in their components section. I'm not sure which bracket I used. I think I ended up modifying the 3 sided upper shock mount bracket. I cut the upper spring pocket and shock mount off of the stock frame. I will try to get a picture later today.
BonzoHansen
12-23-2022, 09:54 AM
Speedtech
Jimmy Sean
12-29-2022, 06:15 AM
BMR sells a kit https://www.bmrsuspension.com/?page=products&productid=1159&superpro=0
b17brian
12-30-2022, 09:24 AM
Speedtech Chicane coil over mount brackets.
TheJDMan
01-04-2023, 08:23 AM
If you plan on using the stock sub frame, it needs to be welded along all the seams in order to stiffen it. From the factory they just stitch welded the subframe in short beads leaving areas unwelded which tend to flex when under heavy cornering load.
