View Full Version : New to the group 1976 chevy corvette
Todds76
12-16-2022, 09:32 AM
Hello new to the group. Thought I would share some info and pictures of my build. It is a 1976 corvette that I have done an LS swap the engine is a 408 stroker with a t56 magnum trans. At the body shop at the moment getting the flares installed. Wheels are 18x10 and 18x12 CCW cl204146204147204148204149204150assics.
76-Vetteman
01-10-2023, 01:56 PM
I'm a 76 Corvette guy as well. It will be fun watching this build..
Todds76
01-13-2023, 07:03 AM
Hey vetteman what are you doing to your car ? Any pictures ?
badbu68
01-13-2023, 12:43 PM
Oh man, love those headers into side pipes. Very cool build. What color scheme interior/exterior?
Todds76
01-14-2023, 01:26 PM
Not sure on color yet but leaning towards black. Interior will be black.
76-Vetteman
02-26-2023, 10:55 PM
Hey Todd76 sorry for the late reply.
I don’t have photos of the build, but I will have some as the disassembly begins soon.
I’ve been busy gathering tools; parts etc, for quite a while.
The build plan is to configure the chassis with C6 suspension, front and rear, so the frame will have to be modified. The electronics will all be C6 where the engine control module and the body control module will communicate across the GMLAN. Body wiring will all be C6. The engine base will be a GM Big Block 8.1L Vortec 496. It has a cast iron block but the intake, the heads and the oil pan will be cast aluminum. The weight will be less than a 454 but will produce much more power.
I can go on and on about this but I believe you can see where this is going.
If you want to check out the capabilities of the Vortec 496 hop over to Raylay Engineering, and on the Hot Rod Performance page you'll find a link to a PDF of a 496 being stuffed into a 69 convertible. Look for the banner/link on the right side of the page, half way down, 8.1L Hot Rod Swap – ’69 CORVETTE
Good luck with your build. I will continue to follow your progress..
About your body color. Black will be great but the body must be perfect. Keep in mind, the 76 can wear any color well.
BillT
Tampa33
02-27-2023, 03:23 PM
wow nice work!
nice job fam
