TANKMASTERJ
12-06-2022, 05:05 PM
Ok, Long Story but 67 camaro with Early 2008 LS& with E38 ECM Swap. Came out of a burned wreck with new intake and injectors, throttle body etc.
Car ran great to almost WOT and about 6K Plus had limp mode every pull. After much tuning crap and hair pulling, I discovered that what I had came with a gold blade later LS3 style throttle body. My Earlier VIN Vette LS7 actually came with a Silver Blade Throttle Body, so I ordered one, swapped, did a throttle relearn and she ran like a top into over 7 grand no REP, no Limp, no Dead Pedal. For about 3 months. Then one evening while driving home from church, I had an all of the sudden tail lights go out and fuse pop. So tracked that to an extra insulated Jacket Male Connector I had left hanging that touched ground. It was feeding the hot to my gauge pack. So when it happened I lost all Dash and Gauge Lights as well as Tail Lights.
On the way home while driving AFTER that happened i hit Limp Mode Dead Pedal in 4th gear in a slight pull.
Didnt think much about it but came in the shop, found the Male Connector Shorting out on the Steering Column, Plugged it with a dummy female, replace Fuses and all was fine.
Except the Dead Pedal. Now if I turn Key On, Cycle Pedal, Pedal goes immediately Dead with Codes P0122, P1516 and P2135.
Now P1516 I was seeing with the old Gold Throttle Blade.
So I did a Throtte Relearn and no change. But If I turn Key On , Cycle Pedal, then Run Diagnostic with HP Scan, Then Start and run it runs great for a little while, then randomly back to Dead Pedal all the Way, or REP Limp Mode then Dead Pedal.
Could my lit e Wire Short Deal somehow Shorted out my Pedal or Throttle Body TPS or TAC??
All was Fine until that Incident.
. The Wire that shorted out is in the Car Harness, Nothing to do with the Swap Harness. Fused Separately and all.
Any Help is appreciated.
Jason
Jason
