View Full Version : S1 Sequential Shifter T56/ Magnum F series 6 speed
jwcarguy
11-29-2022, 12:46 PM
I have a basically new S1 Sequential Shifter assembly for GM T56 F-body and Magnum F-series 6 speed manual transmissions
Right side lever configuration
It has both cams and shaft fittings for either the GM T56 or the Magnum F series Tremec 6 speed manual transmissions (this optional conversion kit costs $80)
Has Magnum F purple cam setup in it now
Have the optional Digital Gear Indicator and Gear Position Sensor
Has the black Delrin S1 Shift Knob
This was mocked up in car, then build changed directions to an automatic transmission setup, the rear block/ plate was never drilled or pinned
$1400
[/FONT]in Las Vegas, NVshipping is additional
