View Full Version : 15/16 Wilwood compact master cylinder - lightly used
FLYNAVY53
11-28-2022, 07:10 PM
Typically I'm a stickler for attention to detail, in this case, I failed. I intended to order the 15/16 Wilwood compact master cylinder specific to the C2 Corvette (which has a shorter pushrod). Instead, I ordered the generic piece with the longer push rod. Of course, I did not realize this until after I had assembled everything and bench bled the unit. So, my stupidity is your gain. I drained the master, filled with brake cleaner, bench bled again to ensure all brake fluid had been removed, and drained all the brake cleaner and wiped the unit dry. Included with the master are all 4 fittings, as well as two additional fitting to adapt the inverted flares to -3 AN should you choose, and the 4 stainless screws for the lid.
$290 shipped. I ship via UPS, and I do my best to get it out same day as payment is received, within 24 hours at the latest. I can take Pay Pal or VENMO.
Feel free to call or text with questions. 585-746-9022
Cheers,
Greg
203701203702203703
FLYNAVY53
12-03-2022, 08:23 PM
make a reasonable offer.....not doing me any good!
