StevieBB54
11-10-2022, 02:07 PM
If anyone is interested in doing a 4 speed conversion I have almost everything you would need. I am going to install a TKX and want to sell the Muncie set up. I am putting this up in case anyone is interested, it is in the car (68 Camaro BBC) now and runs perfect. You can come and see for yourself the operation. The trans runs quiet and does not jump out of gear (everything set up correctly).
Has billet steel flywheel, bellhousing, recently rebuilt M 20 from previous owner about 600 miles on it, newly rebuilt Hurst Comp+ shifter with new correct rods and steel bushings, new BB X member/mount, new/correct back up light switch and harness, comes with pedal/Z bar and pedal linkages, including a speedo gear kit to set up with your tire size.
When I had the trans out 500 miles ago, I opened it up: the gears were in excellent condition and synchro rings looked new with no wear pattern at all. Let me know if interested, it is located in the San Francisco bay area, I wont be pulling it out for a good couple of weeks, if no one buys it I will just make a video to have on hand.
may include fairly new driveline with 1310 U joints also.
Only things that will not go with the system is the 4106 Hurst lever, flywheel/PP/bellhousing and trans mounting bolts (ARP, going on conversion).
Im thinking somewhere around $1200 for everything is in the ballpark. More pics upon request.
203388203389203390203391203392
