Kyle Simpson
11-08-2022, 06:30 PM
This 68 Camaro known as THE ROACH ( No Limit Engineering former shop car) is almost ready to sell. I'll go ahead and post it here while I'm finishing up a few things. The tune is still being sorted out, and AC has to be recharged. Rear axle seals have a SLIGHT leak but nothing terrible. That is ALL this unit needs! This is a very purpose built car that you can race, take on mountain runs, or drive on the street. It will take a turn as fast as you wanna go. This is arguably the finest chassis you can run under a 1st Gen Camaro. To duplicate this chassis setup, it's $40k in parts and labor at No Limit Engineering. You can research the first part of this build here. This is yhe car Rob McGregor developed their 1st Gen Fbody parts on. Here's the long list of parts:
Body/chassis
New paint in 2019 and glass/rubber/seals.
No Limit Sniper IFS front end
Front inner fenders widened
No Limit 3-link rear (rocker arm/cantilever setup). Coilovers and sway bar in trunk
Rear floor raised 2 inches to house rear susp.
RideTech Coilovers
Speedway swaybars front and rear
Coleman Racing rack and pinion steering
Moser 9” Full floater rear, 3.73
Detroit Speed Tru-Trac
Weld-in SFCs
6 point cage
No Limit side rail stiffeners
DSE Minitubs
Brakes/wheels
No Limit balance bar, Wilwood master
TBM 13” wave cut rotors
TBM 4 piston calipers on all 4 corners
Forgeline SC3C 18x11s
315 Falken tires front and rear
Motor/Trans
383 Stroker. Scat rotating assembly. 4 bolt main block, Vortec heads, Lunati cam, 400 rwhp
Holley Sniper EFI
T56 6 speed trans
Turn1 Powersteering Pump
Magnaflow stainless exhaust
Aluminum Rad, dual elec fans, external P/S Cooler and Trans Cooler
No Limit fuel tank, 340 in-tank Pump
Interior
Autometer Gauges
New carpets
Rear seat delete
Recaro Seats, 5 point harnesses
IDIDIT tilt/tele column
All new American Autowire Harness
Trunk mounted battery in rear with cut-off
Vintage Air HVAC
JVC stereo. Bluetooth, Pinoeer speakers front and rear, Sub and amp in trunk
$67k cash sale, located in Spartanburg SC
864 597 6885
Tons of pics and video available 20332320332420332520332620332720332820332920333020 33312033322033332033342033352033362033372033382033 39203340203341203342203343203344
Body/chassis
RideTech Coilovers
Weld-in SFCs
6 point cage
DSE Minitubs
Brakes/wheels
Motor/Trans
Holley Sniper EFI
T56 6 speed trans
Interior
Autometer Gauges
New carpets
Rear seat delete
Vintage Air HVAC
864 597 6885
