Results 1 to 7 of 7
10-24-2022 #1
Noise From rear end after ride tech 4 link install - anyone else?
Hi friends,
I originally had my LS2/tremec magnum swapped 69 camaro set up with Hotchkis dropped leaf springs and the car seemed to run fine with the exception of a vibration I got due to poor driveline angle at about 80 mph. In order to address the driveline issue I installed a ride tech 4 link system and immediately began noticing a noise coming from what appears to be the rear end. Prior to the installation the noise was never there so I had the tunnel cut out and used a speedtech trans tunnel piece and had the driveline checked several times. I first thought that on installation I might've further compressed the crush sleeve in the rear end so I went in this weekend replace the crush sleeve and checked all measurements of the rear end. Car operates well with the exception of a whirring noise that starts at 35+ mph, almost like a slight tire rubbing, it intensifies on deceleration. Anyone else run into this issues with the 4 link and any possible solutions? thanks
