jchrobak
10-18-2022, 06:30 AM
Car partially restored but needs to be finished
Body and paint done (could use a cut & buff when car is completed)
Interior done (could use some TLC when done. i.e steering wheel, radio, speakers etc..)
Drivetrain is LQ9 6.0L with a stage 1 cam and LS9 head gaskets.
6-Speed T-56 Tremec with stage II American Power Clutch
Corporate 8.5" 10-bolt rear with 3.73 gears
Electric Rally Sport headlights (need to be wired)
Upgraded GMPP valley cover with built in PCV.
All wiring there and in place, car was previously wired. Obviously needs some buttoning up. Wiring needs to go to the front end lights & gauges to each sending unit/pickup. The ECM harness will need power & the harness connected to each pickup. All wiring is in tact from firewall back and covered by Dynamat & new carpeting.
4-Wheel wilwood disc brakes. Lines are bent and run they need to be connected to a master cylinder.
Exhaust needs to be completed (manifolds included)
Driveshaft needs to be made
Probably missing a bunch but this is a good start
Instead of starting at $45,000.00 I firmly will be asking $39,500.00 and its located in Sarasota, FL 34233
Working on pics... in the meantime (941) 993-4060 will work2028502028542028472028512028552028482028522028 45202849202853202846202850202854202847202851202855 202848202852202845202849202853202846
