View Full Version : Temperature Sensor
elwaupo
09-27-2022, 03:56 PM
Does anybody know which temperature sensor (part number) is recommended for the Holley Sniper? I saw on YouTube it’s a tx3 but I want to make sure if there is a specific part number for it
ryeguy2006a
09-28-2022, 07:40 AM
Should be in the instructions.
andrewb70
09-28-2022, 09:04 AM
TX3 is the Standard Motor Products part number for the CTS in the Sniper. Let me know if I can help with the tuning.
elwaupo
10-08-2022, 11:33 AM
I just ordered one from Holley and that fixed the problem. The problem I’ve been having if cooling, I can’t keep the temperature from climbing. I’ve changed the water pump, thermostat, changed to a 2500 cfm electric fan, went back to a stock 3 row radiator which I flushed out and still can’t keep it from climbing. I’m wondering if this Summit fan shroud might not be letting enough air go through it. I’ll probably go back to a stock set up to see it that’s the culprit, what else can it be?
andrewb70
10-08-2022, 11:35 AM
Post pictures of your fan and shroud
dhutton
10-08-2022, 12:21 PM
The trouble is that most fan cfm ratings are completely bogus. I trust Spal fan ratings and no one else. Cold Case for example has complete BS for their fan ratings.
A better indicator is current. A decent fan is going to consume a lot of current, roughly 30 amps or more.
A two row aluminum radiator with 1” or larger tubes should outperform a stock 3 row radiator by a wide margin.
Don
marolf101x
10-08-2022, 12:43 PM
When do the temps climb?
If when sitting still, it’s not moving enough air through the core; so crappy fan, fan not covering enough of the core without a shroud, or shroud too close to core and not allowing air through.
If when going over 40mph you have all the airflow you need. So it could be the fan/shroud blocking the core, not an efficient radiator, etc.
Also how high does it get?
I hear it all the time, “my LS is running hot”. I ask how hot? “200-205”.
That’s not hot, that’s just getting warm.
andrewb70
10-08-2022, 01:31 PM
Vintage Air sells a monster 850 watt fan for first Gen Camaros. I have a couple of customers using it and it works well. You won't be able to run it with the Sniper, but Spal offers a little stand alone controller for it.
Look up VA part number 371253
The instructions have a lot of good information.
dhutton
10-09-2022, 05:17 AM
Make sure your fan isn’t running backwards, pushing instead of pulling. It happens…. :)
