View Full Version : Pinion angle speedtech torque arm
Shotaro
09-27-2022, 12:35 AM
1970 Camaro Is the pinion angle correct?
202420
202421
dhutton
09-27-2022, 03:41 AM
Your pinion is higher than your transmission. It will likely vibrate. Raise your transmission as high as you can get it and reduce pinion angle. Ai least that is what I would do.
Don
Shotaro
09-27-2022, 04:52 AM
Don
Do I need to raise the engine mounts as well?
Lowering the ride height with coilovers raises the pinion.
[emoji17]
andrewb70
09-27-2022, 12:29 PM
[emoji17]
No, just raise the back of the transmission as high as possible, leaving the engine mounts alone. Lowering the ride height in the rear changes the rear operating angle.
Shotaro
09-28-2022, 03:23 AM
https://speedtechperformance.com/product/70-81-camaro-t56-transmission-tunnel-cover/
I will test the product when it arrives. "How many times should I do it?"
jwcarguy
09-28-2022, 12:29 PM
Don
Don, clear your pm inbox, tried to send you a message, but says it is full
Jeff
Shotaro
09-29-2022, 01:52 AM
Don
I raised the transmission and the numbers changed a little. Correct?
Shotaro
09-29-2022, 01:53 AM
andrewb70
09-29-2022, 09:27 AM
Correct. It will not be a big change, but it will be better.
Shotaro
09-30-2022, 05:25 PM
2.4 1.7 2.2 pinion angle
Shotaro
10-06-2022, 06:24 AM
I haven't run it, but I changed it.
2.4. 0.0. 1.7 nose down.
