View Full Version : FS: Upgraded 1st gen subframe, RPM Transmissions, Hydroboost, Baer, C5 Acc. drive
rocketrod
09-20-2022, 02:33 PM
ALL ITEMS HAVE BEEN SOLD
SubframeSOLD!!!
- Asking -
Complete front subframe and suspension. Just add brakes of your choice, body mount bushings, wheels and bolt it to your ride.
OEM subframe sandblasted and powder coated satin black
ATS 670 steering box with rag joint coupler
AFX Spindles
GM Fast ratio steering arms
SPC Stage II Upper and Lower Control arms
Varishock double adjustable front shocks
Helwig swaybar
Hotchkis 2' drop coil springs
S&P LS Swap brackets with engine mounts
Stainless steel brake lines
Replaced inner/outer tie rods (Moog)
Hotchkis tie rod sleeves
202597
202599 202600
202598 202601
202603 202602
Transmission - SOLD!!! - The transmission and converter have less than 5,000 miles on them.
4l70e out of 2008 TBSS
Sent to RPM Transmissions for level VI rebuild https://rpmtransmissions.com/products/4l70e-level-vi/
Precision Industries 3200 rpm stall torque converter
SFI Flexplate
Strange Engineering 27 spline billet yoke
Transmission cooler with custom mounting brackets
Transmission temp sending unit/sensor (I have a transmission temp gauge, but currently it will be sold with the DSE dash
Includes custom black braided lines AN fittings to connect transmission to radiator, cooler and sending unit)
C5 Corvette accessory drive - SOLD!!!
GM C5 Corvette accessory drive (p/n 19155167): Includes alternator bracket, alternator, power steering pump, tensioner, belt and mounting bolts
GM water pump (can't find p/n)
GM balancer (p/n 12635649 w\ AN adapters https://www.gmpartsgiant.com/parts/gm-balancer-12635649.html)
Include new OEM balancer bolt
SD7 A/C compressor, polished. Incudes billet adapter for A/C connecting lines
Holley LS A/C bracket (high mount p/n 20-134 https://www.holley.com/products/engine_swap_parts/accessory_drive_brackets_and_kits/parts/20-134
Holley LS A/C bracket/ spacer (p/n 21-1 https://www.holley.com/products/ls_power/ls_and_lt_accessory_drives/gm_ls_accessory_drives/high_mount/installation_components/parts/21-1)
Serpentine belt
All aluminum brackets were sprayed with etching primer then top coated with a light silver 2K paint.
Hydroboost and Master cylinder - SOLD!!! - Willing to ship, but price does NOT include shipping and PayPal fees.
Hydroboost base model purchased from Hydratech
Hydroboost has stainless steel slip cover
Baer Remaster, 1 1/8" bore, black (has about 1,000 miles on it)
Baer proportioning valve, mounting bracket and lines
I can include the stainless steel lines and fittings
drb930
09-20-2022, 07:55 PM
ATS 670 steering box with rag joint coupler -
Any chance you would sell this separately?
rocketrod
09-21-2022, 06:12 PM
Any chance you would sell this separately?Not at this time. Looking to sell as a complete package.
rocketrod
09-25-2022, 05:45 PM
Updated listing - Transmission, converter, flex plate, cooler and lines have been sold
JuStBlAzIN
09-26-2022, 10:35 PM
Do you have any pictures of the hydro boost setup?
rocketrod
10-01-2022, 06:19 AM
Added pics...
boonedogs72
10-08-2022, 09:10 AM
Nice talking to you today rod, I’ll get payment out for the hydroboost next week. Thanks again!
rocketrod
10-08-2022, 09:16 AM
Nice talking to you also. As I said, I'll be out of town next week, but will get the parts shipped the week of October 17th.
SteadfastMFG
10-13-2022, 05:38 PM
What size front wheels and tires were you running with that subframe?
rocketrod
10-14-2022, 01:52 PM
245/40/18s
rocketrod
10-18-2022, 02:45 PM
Payment received, item shipped and I sent you the tracking numbers. Thanks
rocketrod
10-18-2022, 03:25 PM
Lowered price on subframe from $3,700 to $3,300
rocketrod
10-23-2022, 10:40 AM
C5 accessory drive setup has been SOLD!
rocketrod
10-25-2022, 12:23 PM
Lowered price on subframe from $3,300 to $3,000 and the subframe has been removed from the car.
rocketrod
10-31-2022, 03:36 PM
Ttt...
rocketrod
11-03-2022, 08:12 AM
Sale pending.
rocketrod
11-09-2022, 07:58 PM
sold!
